Page 28 of 57 FirstFirst ... 18262728293038 ... LastLast
Results 271 to 280 of 567
Thread: Discover Media retrofit
  1. #271
    Jul 2012
    Brisbane, Queensland
    Does 5K0 919 475 E sound right?
    MY12 Golf R | 5 Dr | Deep Black | DSG | Discover Media retrofit | RVC retrofit | DYNAUDIO
  2. #272
    Sep 2019
    Netherlands
    Hello,
    I'm new in here and want to share my experiences. I have a Tiguan 5N 2014 with factory fitted Dynaudio and rear OPS. I upgraded to RNS 510 and RVC (highline) about some months ago.
    So I fitted Discover Media (Index G) 2 days ago. Everything works as expected (even with older gateway without 5F support), except my Highline RVC (it's just disconnected for now). I nearly read all pages in this thread and I am going to fit newer 7N0...B RVC module + new harness from back to front. I will get a completely new 7N0 module, i hope i can get it calibrated without ODIS?!
    In addition: Right now I have the camera 5N0827566AB installed, will it still work with the new RVC module? Some say yes, some say no (..... AL camera is mentioned instead).
    I will also fit a new PDC module to make the PDC display work together with the RVC camera (but will do that later).
    I managed to configure the Dynaudio amplifier in adaptions + coding, but my feeling is that the sound was way better with the old RNS 510.. anyone else has the same experience?
    Greetings to all dm retrofitters
    VW Tiguan 5N - 2014 - and still happy :o)
  3. #273
    Jul 2012
    Quote Originally Posted by Deezah View Post
    Welkom! I noticed a slight difference but think it still sounds better than most other cars out there.
  4. #274
    Hello,
    You need ODIS S to run RVC calibration routine, as well as the calibration board. It will not complete with the older revision of camera.
    Much easier is to just use an aftermarket camera that doesn't require calibration.
    What exactly are your coding/adaptation settings for amplifier?
  5. #275
    Quote Originally Posted by aswigon View Post
    You'll need to replace it with a 1K8 module (which also needs an adapter harness, or you can repin all the wires)
    Golf VI assembly 1K8 919 475 E
  6. #276
    Jul 2012
    Thanks for the info. I will have to go hunting for some information on where it is physically located as what I have found so far left me confused.
  7. #277
    It's up above the driver's footwell, above the relay carriers. It's a fair way up there behind the dash.
  8. #278
    Sep 2019
    Netherlands
    Hello kamold,
    regarding Dynaudio here's my setup:
    Byte 4-7 - AA000000 2 Channels / 4 Passive Speakers installed (PR-8RH) or Sound system (PR-9VE)
    Byte 11 - 03 External Sound System installed (PR-9VE)
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D => activated
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus => Databus Infotainment
    MAS00950-Audio Parameter => 0
    ENG117919-Startup_Screen_Sticker_HMI => 00 02
    On my car's sticker there is "PR-9VE" noted (I ordered Dynaudio from factory). My amp is 5K0 035 456 C / KonzernAmp 8K H07 0202. I'm missing the sound "dynamics" a bit. The RNS 510 was way better regarding the sound.
    In your entry post you wrote:
    "Address 5F, long coding, byte 11 - change from 01 to 03 (or 05 for original Dynaudio amp)"
    Do I need to change byte 11 to 05 maybe? VCDS is missing that label though, only 01 and 03 is shown, but ofcourse one can enter it manually. With my current setup: balance/fader is shown correctly and it works as expected.
    And does anyone have experience with a converter for the original highline RVC? I'm thinking about trying one out.
  9. #279
    Sep 2019
    Netherlands
    I already wrote a reply, but it needs to be confirmed by a moderator?
    Ok, i edited this post for now:
    Hello kamold,
    And does anyone have experience with a converter for the original highline RVC? I'm thinking about trying one out (although I already ordered the the RVC module + RVC camera + harness).
  10. #280
    Byte 4-7 should be 000000 as you have 8 passive speakers, not 4.
    Byte 11 is correct for Golf Dynaudio 250w amp (03). It's 05 for Passat Dynaudio which is a different 600 amp.
    VCDS label file is not complete.
    You can't use a converter with highline OEM RVC. It doesn't work.
