Page 25 of 58 FirstFirst ... 15232425262735 ... LastLast
Results 241 to 250 of 580
Thread: Discover Media retrofit
  1. #241
    Jul 2019
    Qatar
    I cannot code the RVC module, it gives error "coding rejected" does it require any security access or sumtheng to code it?
    And what about the problem with 5F module: the parkpilot is currently not available"??
    Any adaptation or coding to consider?
  2. #242
    Jul 2019
    Qatar
  3. #243
    Try sa 20103 for rvc.
    Yes there is adaptation required for park assist.
    Take an adaptation channel map and post it.
  4. #244
    Jul 2019
    Qatar
    Hey Kamold,
    sorry for my late response, it took sometime from me to figure out how to export the adaptation channel map it is HERE. and SA didn't work either for 6C module! it is showing error: "Controller refused the key! Error35: Invalid key"
    below is my full auto-scan for your reference
    Dropbox - autoscan.pdf - Simplify your life
    waiting for your feedback
    Thanks.
  5. #245
    Which input do you have your camera plugged into in the RVC module?
    It still shows no video input.
  6. #246
    Jul 2019
    Qatar
    gray plug: Camera to module
    2 pin plug: camera to module
    Brown cable: ground
    Red cable: +12v
    Orange brown and orange violet cables to CAN-+
    White and black cables to MIB pins 6 and 12
    The module is having grey, green plugs connected as well as the red big plug with multipin.
  7. #247
    Oct 2017
    Hello Kamold, Do you know the camera that fits my golf mk6 without using a converter adapter? Passat CC and Golf mk7 sportsvan cameras are compatible, I wonder if you have information about this?
  8. #248
    Here are the pinout differences:
    Discovwer PQ Camera Pinout - Google Sheets
  9. #249
    Quote Originally Posted by HKN View Post
    If you are connecting to a Discover Media, then you can use an aftermarket camera like this:
    For VW VOLKSWAGEN Golf 6 7 MK7 MK6 Passat CC Polo Flip Logo Emblem Camera Badge Rotating Camera Dynamic Trajectory Line CCD-in Vehicle Camera from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
  10. #250
    Jul 2019
    Qatar
    Hello Kamold I got my harness from the below link and I used it exactly as described by connecting the camera and module!!
    VW Wiring loom reversing camera High Line Camera 7N0907441B Camera TIGUAN I, Sharan. VW Kabelsatz Rückfahrkamera High Line Kamera 7N0907441B Camera TIGUAN I, SHARAN. | eBay
    Module is also purchased from this:
    VW Passat cc Facelift 1.4 TSI Control Unit Rear View Camera Rfk 7N0907441B VW Passat cc Facelift 1.4 TSI Control Unit Rear View Camera Rfk 7N0907441B | eBay
    Still black screen for two seconds and then "the parkpilot is currently not available".
    Any Idea on how to test the camera itself and how to remove the error messege from 5F module.
    I'm sorry to bother you that much but I really spent like a week trying to find a solution but with no luck.
