Dobry dzień.
Mam Octavię II FL 2010
Dobry dzień.
I have a 7n0 goal and I would like to mount in the Discaver Pro car. Please, verify the adapter from allxpress which will be correct.
Upgrade Quadlock Extension Adapter Kabel Do Audi A4 A6 Skoda SEAT OPEL BMW VW Golf VI Jetta 5 6 MK5 MK6 Passat B6 w Upgrade Quadlock Extension Adapter Kabel Do Audi A4 A6 Skoda SEAT OPEL BMW VW Golf VI Jetta 5 6 MK5 MK6 Passat B6 od Cables, Adapters & Sockets na Aliexpress.com | Grupa Alibaba
or
BODENLA RCD330 MIB RCD510 Wielofunkcyjne Kierownicy Sterowania Przycisk Symulator Adapter Do VW Golf 5 6 Jetta MK5 Touran Caddy w BODENLA RCD330 MIB RCD510 Wielofunkcyjne Kierownicy Sterowania Przycisk Symulator Adapter Do VW Golf 5 6 Jetta MK5 Touran Caddy od Cables, Adapters & Sockets na Aliexpress.com | Grupa Alibaba
Thank you.
I love my retrofitted MIB2 radio in my Passat. There is only one issue I've been having as of late. Whenever it is 2 degrees or lower (Celsius) the rear camera flakes out. When it was a little warmer, it would be black screen when I started the car first thing in the morning and on the way home (5pm so warmer out) it would be working just fine. The camera is original, and would always work, so thinking it is wiring into the MIB or the retrofit adapter for the RCA cable. Any thoughts or ideas to troubleshoot this one?
If you have original camera I'm guessing you are using an RGBS to CVBS converter? They can be a bit hit and miss. You can replace the camera with a cheap aftermarket composite camera and go straight into the Discover media and get a better picture.
@kamold,
I have been reading your posts here with interest. I have a Mk6 2012 R that has RNS510, dynaudio, Reverse camera and bluetooth factory fitted. I am interested in upgrading to the Discover Media system but don't have the skillset or time to complete the upgrade. Wondering if you offer this service and can supply parts. I'ld like to replicate all functionality with the current setup with the addition of Carplay and DAB.
Andrew
Hi I have retrofitted RCD310 to Discover media 5c0 035 680C mib std2 pq35 + navi. I have the same sympthoms for RVC (when tailgate open, OPS visible and icon gray, when tailgate closed rvc video visible but without OPS and without icon on left toolbar). Images here OneDrive . I would like to ask you, did you have to replace your sensors or not?
I have 1k0 ... 475K bosch pds module and 7L5 919 275B sensors.
Do you know if I can replace covers and sensors keeping my bumper with current holes? Does diameter of hole is different or the same for both sensors? I know that sensors has different construction, but using rubber o-ring with cover from scirocco 2015 or jetta could do the work?
You don't need to replace the sensors, just the PDC module.
Are you sure that Bosch sensors will work with Valeo PDC? Guy in carsystems.eu said that Bosch sensors have different harness than for Valeo. They can help with reassign pins to new plugs when I will buy PDC from them, but in case that sensors were also valeo. I know that I can connect Valeo PDC 1k8, but I do not know if Valeo sensors has more or less wires than Bosch.
Also I wonder if parameters for different sensors will be ok to work correctly. I think that the fastest way to check if 1k8 will work with my Bosch sensors will be plugging adapter to new unit without removing anything from car.
Don't touch the RCD330 unless you're after a budget install. The sound will be a downgrade from your factory unit (depending what you have), and you'll forever find bugs. I pulled mine out after a little over a week and went with a Composition Media install.
CM vs DM is at a very basic level a choice between Sat Nav or not. I went CM, because no on-board navigation really compares with Google Maps, so there was not point paying extra, when everything you need comes with Android Auto / CarPlay.
Installation wise, everything was pretty straightforward with CM, albeit not quite as straightforward as an RCD330
