Page 11 of 57 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 567
Thread: Discover Media retrofit
  1. #101
    Jan 2017
    Thanks Kamold - that's definitely a surprise!
    Sounds like PDC upgrade then. Although knowing that it can send OPS if there is a camera, I might have a play to see if I can trick the PDC into thinking it has a camera and sending the right signal - as you did say you were able to get OPS on its own, when you were trying to get camera as well...
  2. #102
    Quote Originally Posted by Simo View Post
    Only trouble with coding for a camera is you will just get a black screen when you select reverse.
    When you go back to a forward gear you should get the ops screen though...unless it only works with a highline camera module. Not sure about that as I have an upgraded compatible 7n0 highline camera module installed now.
    I have a spare 1k8 PDC module but don't have a harness. Can get a harness from Aidu auto.
  3. #103
    Jan 2017
    I did try coding the camera on the weekend and got a blank screen, but no OPS when going out of reverse - maybe I should just drop that idea... Shoot me a PM with a price, and I'll buy the PCD module off you.
  4. #104
    Apr 2009
    The Little Red Dot Singapore
    This has been a few months in all to get this project to completion but it has been worth the effort
    Dynaudio Amplifier
    New amplifier 3AA035466 from a Passat CC
    Original (also retrofitted) amp was 3C0035456F
    This is a simple plug and play swap.
    *UPDATE*
    This is not needed (tested and confirmed), there is now coding which will allow the original amp to work (see below)
    If you have a car with immobilizer in the cluster (ie Golf, Tiguan etc) and a 3D colour instrument cluster with software version ABOVE 0705, you will need to get a quadlock harness adapter than includes a CAN filter to prevent component protection message exchange between the MIB unit and the instrument cluster.
    When I first installed the unit it was not correctly configured for an external amplifier. There is both coding and adaptation channels which need to be set:
    Address 5F, long coding, byte 11 - change from 01 to 03 (or 05 for original Dynaudio amp)
    Address 5F, adaptations:
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ==> change to activated
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ==> change to "Databus Infotainment"
    MAS00950-Audio Parameter,0 ==> change to 1
    ENG117919-Startup_Screen_Sticker_HMI ==> 00 02 for Dynaudio
    This correctly configured the unit for an external amplifier and allowed the balance/fader to work correctly.
    Hi Kamold,
    I got my hands on a patched Discover Media from Europe. It worked great with the instructions you have provided above. I have on problem on the Fader function which was available on my RNS510 on the B7 Passat. The set came coded but there was no fader and I could not get the sound to work correctly then ( with Byte 11 changed to 05, it worked perfectly ). With your instructions, we rectified the sound issue but there is still no fader.
    Is there any way I could get the FADER function to appear ? Currently I have only the BALANCE available.
    Thanks !
  5. #105
    Hi Jimmy,
    Do you have an amplifier?
    If so is it dynaudio or VW Sound System?
    Quote Originally Posted by cbx750p View Post
    Hi Kamold,
    Thanks !
  6. #106
    Apr 2009
    Hi Jimmy,
    It is Dynaudio 10 Channel 600Watt original VW part which was retrofitted. The sound was perfect on the RNS510 but due to the ever worsening lag on the RNS, I am planning to upgrade it to the Discover Media unit. Until I got hold of your post, I was struggling with the Byte 11 coding. Finally with bit 5, it worked. The sound is much much better now, in fact better than that of the RNS510.
    Address 47: Sound System Labels: 3C0-035-456.lbl
    Part No SW: 3C8 035 456 E HW: 3C8 035 456 E
    Component: DSP 10 Kanal 0080
    Revision: 00H02001 Serial number: 75806000102701
    Shop #: WSC 00000 000 00000
    VCID: 2A51ED9285A11F6E00-807E
  7. #107
    Ok same as mine.
    Likely you just need to change your adaptation in the discover to correctly match amp:
    MAS00950-Audio Parameter,0 ==> change to 0
  8. #108
    Apr 2009
    Those instructions I have already followed to the dot including the Byte 11 to 05 bit. Still can't seem to see the Fader display. Don't know what I am missing. Is there other adaptations that I need ? Or even coding on the DM2 ?
    Another strange episode is that when I fitted the same DM2 to a Golf 6 with Dynaudio amp, there is absolutely no sound coming out from the speakers. When we fit back the car's original RNS510, the sound was also gone. Had to unplug and reconnect the amplifier before the sound appears again. That method did not work when we fit the DM2 on the car. The amp used on the Golf is :
    Address 47: Sound System (R12) Labels: 5K0-035-456.clb
    Part No SW: 5K0 035 456 HW: 5K0 035 456
    Component: KonzernAmp 8K H06 0340
    Tried it on another Jetta mk6 which does not have any sound system, it worked perfectly. Both vehicle we had to install the adapter with the CAN filter. Strangely, on my Passat B7, I did not need the adapter with CAN filter.
  9. #109
    CAN filter is only required for cars with a cluster with software newer than 100x.
    I've seen the sound system amps play up from time to time. Sometimes unplugging and replugging brings them back to life, other times just going into diagnostics with VCDS and then back out will revive it.
    The balance/fader thing I seem to remember seeing one time but it was only when there was something wrong with the coding of the DM, or it might have been adaptation....I can't remember sorry!!
    Let me have a look through my coding and adaptation and see if I can remember. It was just something I saw once while mucking around and so I just changed it back when it wasn't working....something to do with trying to get the amp profiles like with the MQB Dynaudio I think...
  10. #110
    Apr 2009
    Ok same as mine.
    Got it ! Finally !
    In your first post, you instructed that the MAS00950-Audio Parameter, should change from 0 to 1 but your latest instruction indicated "0".
    Tried it just now and the Fader came home !
    Now I got most items working. Got to downgrade my Rear View Camera from Highline to Lowline. Gonna to use the Golf 7 fixed line camera and forego the trajectory guide lines.
    Will keep you posted on my venture.
    Thanks !
