This has been a few months in all to get this project to completion but it has been worth the effort
Dynaudio Amplifier
New amplifier 3AA035466 from a Passat CC
Original (also retrofitted) amp was 3C0035456F
This is a simple plug and play swap.
*UPDATE*
This is not needed (tested and confirmed), there is now coding which will allow the original amp to work (see below)
If you have a car with immobilizer in the cluster (ie Golf, Tiguan etc) and a 3D colour instrument cluster with software version ABOVE 0705, you will need to get a quadlock harness adapter than includes a CAN filter to prevent component protection message exchange between the MIB unit and the instrument cluster.
When I first installed the unit it was not correctly configured for an external amplifier. There is both coding and adaptation channels which need to be set:
Address 5F, long coding, byte 11 - change from 01 to 03 (or 05 for original Dynaudio amp)
Address 5F, adaptations:
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ==> change to activated
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ==> change to "Databus Infotainment"
MAS00950-Audio Parameter,0 ==> change to 1
ENG117919-Startup_Screen_Sticker_HMI ==> 00 02 for Dynaudio
This correctly configured the unit for an external amplifier and allowed the balance/fader to work correctly.
