Originally Posted by
kamold
Sorry I'd forgotten about the ELV as I'd already upgraded my CCM previously.
Yes you need to clone your immo data to a new B7 CCM and modify the wiring to resolve it fully.
If you put the 3c0 gateway back in you won't be able to access the composition media unit via diagnostics, however if you leave radio at address 56 enabled, I think you should still be able to control the volume etc from the steering wheel...one way to find out...
Can you post a full autoscan so that I can see the full parts list and coding then I can look at the PDC issue.
Thanks Kamold - I should send you some beers!
Swapping back the old gateway was definitely the way to go. ELV issue gone, and surprisingly communication with the MFD is still as good as it was with the 7N0 gateway, and better than it was with the RCD510 - I can see what's playing, skip tracks, and see who's calling. Win!
Still no parking display - my guess is I still need the newer park assist module to communicate with the head unit, but in reality, I'm just guessing.
I've removed a bunch of thing from the scan like ABS and Door Electrics to fit in the character limit, as I figure they'll make no difference
VCDS scan with the 7N0 Gateway:
Code:
Sunday,06,May,2018,15:02:33:38493VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWZZZ3CZAE038764 License Plate:
Mileage: 94960km-59005mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 36 42 44 46 47 52 53 55
5F 62 65 72
VIN: WVWZZZ3CZAE038764 Mileage: 94960km-59005miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 012 E HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1982
Revision: 04844002 Serial number: 00000906161234
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 120555150DF9DCD4BE-8046
No fault code found.
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000003285402
Coding: E6868F0700041A00470A00000F000000000A59435C000120000000000000
Shop #: WSC 05124 000 00000
VCID: 334BF09152A335DCD5-8066
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 300709 022 0601
Coding: 00046997
Shop #: WSC 05124
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 260809 046 0204
Coding: 00208933
Shop #: WSC 05124
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 A HW: 3C8 919 475
Component: PARKHILFE 8K H07 0009
Revision: -------- Serial number: 08740921503229
Coding: 100101
Shop #: WSC 12345 123 61029
VCID: 3245F5956DB93CD4DE-8066
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0030
Revision: 00032000 Serial number: 3C5953507CN
Coding: 0001211
Shop #: WSC 05314 000 00000
VCID: 74C9338D172D72E40C-8020
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0030
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3C0 920 872 E HW: 3C0 920 872 E
Component: KOMBI H02 0206
Serial number: 00000000000000
Coding: 160F00
Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 277314C15E7B497C79-8072
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 22041600F12287
Coding: 350003
Shop #: WSC 00046 123 12345
VCID: 7BDB18B1FA733D9C4D-802E
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AM HW: 3C0 959 433 AM
Component: IMMO 052 0383
Revision: 00052000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 75CF0E891C576BEC3B-8020
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
1 Fault Found:
02823 - Requirements for Locking the Steering Column Lock not met
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 0
Mileage: 94963 km
Time Indication: 0
Date: 2012.09.26
Time: 00:30:28
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 143 2901
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 2F43FCE1BE8B113CB1-807A
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ46 RDK 052 0412
Coding: 00910A0001860E76300494157008DFCE105801
Shop #: WSC 05311 000 00000
Subsystem 1 - Part No: 1K8 951 605
Component: LIN BACKUP HORN H09 9002
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218198613822
ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
ROD: EV_AudioVerst8KanalBNO2.rod
VCID: 67F354C19EFB897CB9-8032
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000006790
Coding: 0000057
VCID: 2C79EBED8F9D6A2494-8078
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5K7 035 200 D HW: 5K7 035 200 D
Component: MU-S--ER H22 0245
Serial number: VWZAZ2R8010691
Coding: 028401000000000011110003001828001F0100C60020010002
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW27.rod
VCID: 256F1EC924775B6C4B-8070
1 Fault Found:
1564 - Microphone 1
B129B 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 1
Mileage: 94964 km
Date: 2018.05.06
Time: 21:24:57
Voltage terminal 30: 11.6 V
End-------------------------(Elapsed Time: 01:58)--------------------------
