Page 8 of 57 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 567
Thread: Discover Media retrofit
  1. #71
    Mar 2018
    Buenos Aires
    Great!
    Thanks for your help
  2. #72
    Jun 2013
    Qld
    Hi everyone.
    Can we increase the number of options on this display.
    Only Steering angle, compass, oil temperature and altitudes are available.
    What about all the others sensors.
    Coding maybe?
    (Amarok V6 highline MY1
    Thanks.
    Jerome.
    Sent from my SM-G965F using Tapatalk
  3. #73
    Quote Originally Posted by jeromeo View Post
    Hi everyone.
    Coding maybe?
    Thanks.
    Jerome.
    Those options aren't available on retrofitted discover units as the feature requires an activation code.
    Be happy to take a look at it for you but would need an adaptation channels map of your 5F infotainment unit as well as the coding and adaptation for 17 instruments.
  4. #74
    Jun 2013
    Qld
    This is not a retrofitted unit.
    It's the factory OEM. Discover media. Mib2.
    I can give you model number if it helps.
  5. #75
    Yes that's my point.
    You've posted in the retrofit thread...
  6. #76
    Jan 2017
    I only just updated to the RCD330, but I'm thinking of dropping a Composition Media unit in my late 2009 R36 instead. Part number 5K7035200
    My gateway is SW: 3C0 907 530 L, HW: 3C0 907 951 - so from what I'm reading this will need to be physically upgraded. Correct?
    I have the white MFD, so I understand no CAN filter is required. Correct? If I do need a CAN filter, what exactly am I looking for? Google is not being my best friend right now.
    Is there anything else I'm missing?
  7. #77
    Quote Originally Posted by Simo View Post
    Yes you need a 7N0 gateway.
    CAN filter is not required however the Composition Media unit needs to have been physically patched or it will trip Component Protection after 8 hours of runtime and be useless at that point.
  8. #78
    Jan 2017
    Thanks Kamold - do you know if the gateway still needs to be at least a BC revision?
  9. #79
    Can't say with certainty as I've never seen a composition media but it would be a safe bet to assume as much.
  10. #80
    Jan 2017
    Final question... I hope!
    I can see you've upgraded to the B7 steering wheel, whereas I'm assuming those of us with an original 8 button, will have some issues.
    I purchased this adapter (part BD-ITQAC17820) to get all my buttons working on an RCD330 - would it be as simple as using the same adapter to get them working with Composition/Discovery Media?
