Page 9 of 57 FirstFirst ... 789101119 ... LastLast
Results 81 to 90 of 567
Thread: Discover Media retrofit
  1. #81
    Quote Originally Posted by Simo View Post
    Final question... I hope!
    I can see you've upgraded to the B7 steering wheel, whereas I'm assuming those of us with an original 8 button, will have some issues.
    I purchased this adapter (part BD-ITQAC17820) to get all my buttons working on an RCD330 - would it be as simple as using the same adapter to get them working with Composition/Discovery Media?
    Discover and composition media work perfectly fine with the older wheels.
    No adapter required like with rcd330.
  2. #82
    Jan 2017
    Thanks Kamold - you've been an absolute superstar with all my questions!
    That is not what I expected - I thought an 8 button wheel would be a no-go immediately!
    If I'm not wrong, won't a Discover/Composition Media retrofit will still need an adapter harness like this to go from the older style pin assignment to new assignment for a MIB2 unit? I couldn't in your breakdown (only a new harness for the camera).
    Did you have a different solution?
  3. #83
    Yes there is a quadlock adapter harness required.
  4. #84
    Jan 2018
    Hi so i have a headunit from mk7 2013 golf with nav etc. Wondering what model units i can upgrade and fit in there as my current one has an annoying buzz coming from the screen.
  5. #85
    Quote Originally Posted by Clinton View Post
    You can retrofit an MQB MIB2 unit.
    Will also need a new screen (you can use either the 6.5 in or upgrade to 8 inch if you get the surround trim and vents also)
  6. #86
    Jan 2017
    Great write-up Kamold - I followed it to the letter for my Composition Media install, and it all works a charm.
    Except I can't seem to figure out the following:
    1. Parking distance works, but I'm not getting an image on the screen, just the beeps when I'm near an object. Anything that looks like the right coding to enable it does nothing - have I missed something?
    2. I have the dreaded "Steering column lock! Visit workshop!" warning on the MFD (and the steering wheel will not lock when parked), due to the 7N0 Gateway being incompatible steering lock - do I need to upgrade the steering lock, or is there a different solution?
    Any ideas?
    Code:
    Sunday,06,May,2018,15:02:33:38493
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.2.0.3 (x64)
    Data version: 20180212 DS287.0
    www.Ross-Tech.com
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 36 42 44 46 47 52 53 55
              5F 62 65 72
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
       Part No SW: 5K7 035 200 D    HW: 5K7 035 200 D
       Component: MU-S--ER      H22 0245
       Serial number: VWZAZ2R8010691
       Coding: 028401000000000011110003001828001F0100C60020010002
       Shop #: WSC 01357 011 00200
       ASAM Dataset: EV_MUStd4CTSAT 001022
       ROD: EV_MUStd4CTSAT_VW27.rod
       VCID: 256F1EC924775B6C4B-8070
  7. #87
    Any ideas?
    Code:
    www.Ross-Tech.com
              5F 62 65 72
    For ops image on the screen you need to update to a newer park assist module.
    Mentioned in my writeup I think? 1k8 module. It needs a wiring harness adapter as the pinout changed.
    You can use a golf 7 module and reflash it with Passat CC firmware and parameter set.
    Steering column lock error needs a wiring change in the steering column wiring loom.
    Need to check my notes and get the details.
    Bit of a pain you need to kind of lie upside down in the footwell but not too bad. Just need to bridge 2 wires from memory.
  8. #88
    Jan 2017
    Yeah, you did mention it - I thought this might have been just for the overlay on the camera image, which I don't have.
    I saw you did this in your Kamold's R36 thread, but doesn't this also involve an update to the CCM, or can you just bridge the wiring? Some other posts also indicate a CCM update is required.
    Alternatively, now that the unit has been coded to the car with the new Gateway - what do you think would happen if I swapped it back to the 3C0 Gateway? Would it still work?
  9. #89
    Sorry I'd forgotten about the ELV as I'd already upgraded my CCM previously.
    Yes you need to clone your immo data to a new B7 CCM and modify the wiring to resolve it fully.
    If you put the 3c0 gateway back in you won't be able to access the composition media unit via diagnostics, however if you leave radio at address 56 enabled, I think you should still be able to control the volume etc from the steering wheel...one way to find out...
    Can you post a full autoscan so that I can see the full parts list and coding then I can look at the PDC issue.
  10. #90
    Jan 2017
    Thanks Kamold - I should send you some beers!
    Swapping back the old gateway was definitely the way to go. ELV issue gone, and surprisingly communication with the MFD is still as good as it was with the 7N0 gateway, and better than it was with the RCD510 - I can see what's playing, skip tracks, and see who's calling. Win!
    Still no parking display - my guess is I still need the newer park assist module to communicate with the head unit, but in reality, I'm just guessing.
    I've removed a bunch of thing from the scan like ABS and Door Electrics to fit in the character limit, as I figure they'll make no difference
    VCDS scan with the 7N0 Gateway:
    Code:
    Sunday,06,May,2018,15:02:33:38493VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    www.Ross-Tech.com
    VIN: WVWZZZ3CZAE038764   License Plate:
    Mileage: 94960km-59005mi   Repair Order:
              5F 62 65 72
    VIN: WVWZZZ3CZAE038764   Mileage: 94960km-59005miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 02: Auto Trans        Labels: 02E-927-770.clb
       Part No SW: 02E 300 012 E    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1982
       Revision: 04844002    Serial number: 00000906161234
       Coding: 0000020
       Shop #: WSC 44551 111 44551
       VCID: 120555150DF9DCD4BE-8046
    No fault code found.
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
       Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
       Component: Bordnetz-SG     H54 2602
       Revision: 00H54000    Serial number: 00000003285402
       Coding: E6868F0700041A00470A00000F000000000A59435C000120000000000000
       Shop #: WSC 05124 000 00000
       VCID: 334BF09152A335DCD5-8066
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 300709 022  0601
       Coding: 00046997
       Shop #: WSC 05124
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     260809 046  0204
       Coding: 00208933
       Shop #: WSC 05124
    Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
       Part No SW: 3C8 919 475 A    HW: 3C8 919 475
       Component: PARKHILFE 8K  H07 0009
       Revision: --------    Serial number: 08740921503229
       Coding: 100101
       Shop #: WSC 12345 123 61029
       VCID: 3245F5956DB93CD4DE-8066
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C5953507CN
       Coding: 0001211
       Shop #: WSC 05314 000 00000
       VCID: 74C9338D172D72E40C-8020
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           002 0030
    Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb-SRI1
       Part No SW: 3C0 920 872 E    HW: 3C0 920 872 E
       Component: KOMBI         H02 0206
       Serial number: 00000000000000
       Coding: 160F00
       Shop #: WSC 05314 115 00000
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
       VCID: 277314C15E7B497C79-8072
    Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
       Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1682
       Revision:   H56       Serial number: 22041600F12287
       Coding: 350003
       Shop #: WSC 00046 123 12345
       VCID: 7BDB18B1FA733D9C4D-802E
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3C0 959 433 AM    HW: 3C0 959 433 AM
       Component:    IMMO         052 0383
       Revision: 00052000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 75CF0E891C576BEC3B-8020
       Subsystem 1 - Part No: 3C0 905 861 G
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    1 Fault Found:
    02823 - Requirements for Locking the Steering Column Lock not met
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 0
                        Mileage: 94963 km
                        Time Indication: 0
                        Date: 2012.09.26
                        Time: 00:30:28
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 143    2901
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
       VCID: 2F43FCE1BE8B113CB1-807A
    Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
       Component:    KSG PQ46 RDK 052 0412
       Coding: 00910A0001860E76300494157008DFCE105801
       Shop #: WSC 05311 000 00000
       Subsystem 1 - Part No: 1K8 951 605
       Component: LIN BACKUP HORN H09 9002
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
       Part No SW: 5K0 035 456     HW: 5K0 035 456
       Component: KonzernAmp 8K H06 0340
       Revision: --------    Serial number: BP218198613822
       ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
       ROD: EV_AudioVerst8KanalBNO2.rod
       VCID: 67F354C19EFB897CB9-8032
    Address 53: Parking Brake        Labels: 5N0-907-801.clb
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   010       Serial number: 00000000006790
       Coding: 0000057
       VCID: 2C79EBED8F9D6A2494-8078
    1 Fault Found:
    1564 - Microphone 1
              B129B 13 [009] - Open Circuit
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 1
                        Mileage: 94964 km
                        Date: 2018.05.06
                        Time: 21:24:57
                        Voltage terminal 30: 11.6 V
    End-------------------------(Elapsed Time: 01:58)--------------------------
