SandSeeker:hi.
I'm trying to understand the problem here - but I'm not succeeding! I had understood from your first post that the issue was the illumination level of the infotainment screen during daytime ONLY - but somehow the problem seems to have morphed to also include the temp numerals on the HVAC panel.
I'm not sure how the Golf mk6 manages changing cabin light levels - but it's done via a small photo-transistor on the mk7 -which sits between the "8" and "7" numerals on the tacho - like this:
The new MIB in this car has mk7-ish style channels - so I suspect that its roots are probably embedded in MQB platform vehicles (I'm guessing).
Anyhow, the way that the mk7 handles illumination levels as the cabin light levels change is via a set of "X-axis" and "Y-axis" adaptation channels that create a set of reference-points on a sort-of graph. Each reference-point determines the illumination level of the thing being controlled when the photo-transistor voltage reaches the specified value. This means that the illumination level of various devices can be altered with changing cabin light levels - by changing the adaptation channel values!
The set-up works like this:
- Each X-value channel defines a 12 x bit A/D (Analogue-to-Digital) conversion of the Photo transistor output voltage
- Each Y-value channel drives a 6 x bit D/A (Digital-to-Analogue) converter output for whatever is being controlled (there are multiple screens/LEDs/Displays that are controlled in this manner on a mk7)
I note that your 5C0035680D module also has 2 x sets of "X/Y" axis adaptation channels that look very similar to the mk7 set-up - but I'm not sure how they operate on a PQ35 platform car.
Anyhow -maybe post-up the current values for the following channels in your new MIB:
Dimming_Ambient_Illumination_Information_Control_U nit-X1
Dimming_Ambient_Illumination_Information_Control_U nit-X2
Dimming_Ambient_Illumination_Information_Control_U nit-X3
Dimming_Ambient_Illumination_Information_Control_U nit-Y1
Dimming_Ambient_Illumination_Information_Control_U nit-Y2
Dimming_Ambient_Illumination_Information_Control_U nit-Y3
Dimming_Illumination_for_Display_Unit-X1
Dimming_Illumination_for_Display_Unit-X2
Dimming_Illumination_for_Display_Unit-X3
Dimming_Illumination_for_Display_Unit-X4
Dimming_Illumination_for_Display_Unit-X5
Dimming_Illumination_for_Display_Unit-X6
Dimming_Illumination_for_Display_Unit-Y1
Dimming_Illumination_for_Display_Unit-Y2
Dimming_Illumination_for_Display_Unit-Y3
Dimming_Illumination_for_Display_Unit-Y4
Dimming_Illumination_for_Display_Unit-Y5
Dimming_Illumination_for_Display_Unit-Y6
Hopefully the channels above act in the same way as on a mk7 and the solution to your display problem is just a coding change (yes, my hunch is a bit of a long-shot, but it's an easy try -so worth considering IMO)
