Page 55 of 57 FirstFirst ... 5455354555657 LastLast
Results 541 to 550 of 567
Thread: Discover Media retrofit
  1. #541
    Jun 2024
    Barcelona
    Hi to everybody,
    I have been reading this thread for some days, as I did the same Discover Media Retrofit, but I'm experiencing a very annoying issue and I can not find the reason. The thing is about the brightness of the unit. For some reason, brightness is not increasing during the day or decreasing during the night, so I can see perfectly during the night but during the day is almost impossible to see what the screen is showing. I have already selected in the settings menu, the very bright option, but it seems that this is not enough.
    Does anyone has experienced something like this? My car is a 2006 Volkswagen Golf GTI. I have updated my gateway and I can select the 5F Address in the Installation List. Could be something about coding?
    The number of the 19-Gateway is - 7N0 907 530 AT - J533 Gateway H52 1663
    The number of the 5F-Head unit is - 5C0 035 680 D - MU-S-N-ER - H31 0369
    The number of the 09-Cent. Elect. is - 3C0 937 049 AJ - Bordnetz-SG - H54 2202
    The number of the 08-Auto HVAC is - 35D 907 044 B - Climatronic H03 0303
    Thank you so much!
  2. #542
    Mornington Peninsula, VIC
    Quote Originally Posted by RBmk6R View Post
    hello Mig,
    thank you for the reply; my mk6 R already had the dynaudio system and i have the 8 channel amp; but if i were to go the route you went, do i need to upgrade to the 10 channel amp??? or can i use the existing 8 channel one and get a helix sub/amp like you did?
    also if i went that route, where would i source a plug and wiring for the said Helix sub/amp...as ones i found on ebay come without.
    also would you be kind and let me knwo how you went about doing the wiring?? i'm kind of NOOB when it comes to wiring stuff and/or splicing into existing wires to make it work
    thanks again in advance.
    The helix in this case is a second amp to the dynaudio one, it creates a virtual subwoofer channel by using the two front speaker inputs.
    Many mono channel amps have this as a feature, but look for high level inputs and auto power on. the (Helix D ONE) is the one I am using.
    In terms of wiring, four wires, Left and Right (+ -) need to be ran from the stock amp, to the location of the new amp (In my case the behind right side pocket in the boot)
    And a new fused wire from the battery to the amp, ground can be ran from a close ground point.
    Check out the pics i took here B7 Retrofitting - MIG's Passat
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
  3. #543
    Quote Originally Posted by SandSeeker View Post
    Hi to everybody,
    Thank you so much!
    Your issue is caused by the CECM (09) module in your case, Unlike the BCMs in newer cars, does not broadcast the backlight brightness on the CAN ID the DM or Climatronic is looking for.
    Check out the project here, Dropbox
    The HBA/Runlock/Automatic start/Brightness PCB module add this missing CAN message to allow the newer modules to work correctly.
    I think you can also set the brightness manually via the adaptation channels, but this is a fixed value (So might be too bright at night)
  4. #544
    Jan 2024
    canada
    Quote Originally Posted by MIG View Post
    thanks for the inputs and pointers.
    i will see which route i'm gonna be taking. i think the sub in teh spare tire is a NO GO for me as the golf R has a spare tire that sits in the boot upside down (convex) so i cant' put a sub in the spare tire.
    i may go the route of getting an enclosure with a sub in it an put in the boot on the one side and mount the amp somewhere in the boot area as well.
    so do i need a line processor like L2Ci to feed the said amp for the SUBWOOFER?? or running the wires from the stock dynaudio amp(you mentioned the output of the 2 front speakers from the stock dynaudio amp); is there a reason why the 2 front ones and NOT the 2 rear speakers.
    also how would i find/know which 4 wires out of the stock dynaudio amp are the 2 front speakers?? can i find a schematic diagram somewhere?
    thanks again.
  5. #545
    Jun 2024
    Barcelona
    Hi @MIG
    First of all, thank you so much for your quick reply. As you said, I have realized that the Climatronic panel does not show the correct brightness in the two small screens showing the temperature number. I understand this is caused by the same issue.
    Also, I have seen the project about the HBA/Runlock/Automatic start/Brightness PCB module. Is this the only way to solve my issue? or there is any other option like swapping the unit 09 Cent. Elect. for another one a bit newer? And also, how could I get this project done to be able to weld it directly to my CECM? I'm new about it.
    About setting the brightness manually, you are right, during the night would be too bright. I prefer to make it work as it should.
    However, I have previously retrofitted other components of my car without any issue, like the steering wheel module to the 1K0 953 549 CH, the Instrument cluster to the 3D FIS one with reference 1k8 920 885 J, the Climatronic with brightness issue and now the Discover Media with Brightness issue as well.
    Thank you so much!!!
  6. #546
    Jun 2024
    Barcelona
    Hi again MIG
    I have tried to contact to the owner of the project by e-mail to be able to buy this PCB in order to correct and fix my issues, but I have not received any answer from the developer of the HBA/Runlock/Automatic start/Brightness PCB module. So I'm still not being able to solve the problem.
    Another option I was thinking about, is to try to find out the pinout of my CECM and also the pinout of the correct needed BCM, to be able to create a converter Harness in order to use a newer BCM Module.
    am I right or am I missing something else? any advice about how could I solve this issue?
    Thank you very much!
  7. #547
    SandSeeker:hi.
    I'm trying to understand the problem here - but I'm not succeeding! I had understood from your first post that the issue was the illumination level of the infotainment screen during daytime ONLY - but somehow the problem seems to have morphed to also include the temp numerals on the HVAC panel.
    I'm not sure how the Golf mk6 manages changing cabin light levels - but it's done via a small photo-transistor on the mk7 -which sits between the "8" and "7" numerals on the tacho - like this:
    The new MIB in this car has mk7-ish style channels - so I suspect that its roots are probably embedded in MQB platform vehicles (I'm guessing).
    Anyhow, the way that the mk7 handles illumination levels as the cabin light levels change is via a set of "X-axis" and "Y-axis" adaptation channels that create a set of reference-points on a sort-of graph. Each reference-point determines the illumination level of the thing being controlled when the photo-transistor voltage reaches the specified value. This means that the illumination level of various devices can be altered with changing cabin light levels - by changing the adaptation channel values!
    The set-up works like this:
    • Each X-value channel defines a 12 x bit A/D (Analogue-to-Digital) conversion of the Photo transistor output voltage
    • Each Y-value channel drives a 6 x bit D/A (Digital-to-Analogue) converter output for whatever is being controlled (there are multiple screens/LEDs/Displays that are controlled in this manner on a mk7)
    I note that your 5C0035680D module also has 2 x sets of "X/Y" axis adaptation channels that look very similar to the mk7 set-up - but I'm not sure how they operate on a PQ35 platform car.
    Anyhow -maybe post-up the current values for the following channels in your new MIB:
    Dimming_Ambient_Illumination_Information_Control_U nit-X1
    Dimming_Ambient_Illumination_Information_Control_U nit-X2
    Dimming_Ambient_Illumination_Information_Control_U nit-X3
    Dimming_Ambient_Illumination_Information_Control_U nit-Y1
    Dimming_Ambient_Illumination_Information_Control_U nit-Y2
    Dimming_Ambient_Illumination_Information_Control_U nit-Y3
    Dimming_Illumination_for_Display_Unit-X1
    Dimming_Illumination_for_Display_Unit-X2
    Dimming_Illumination_for_Display_Unit-X3
    Dimming_Illumination_for_Display_Unit-X4
    Dimming_Illumination_for_Display_Unit-X5
    Dimming_Illumination_for_Display_Unit-X6
    Dimming_Illumination_for_Display_Unit-Y1
    Dimming_Illumination_for_Display_Unit-Y2
    Dimming_Illumination_for_Display_Unit-Y3
    Dimming_Illumination_for_Display_Unit-Y4
    Dimming_Illumination_for_Display_Unit-Y5
    Dimming_Illumination_for_Display_Unit-Y6
    Hopefully the channels above act in the same way as on a mk7 and the solution to your display problem is just a coding change (yes, my hunch is a bit of a long-shot, but it's an easy try -so worth considering IMO)
  8. #548
    thanks again.
    That L2Ci creates the virtual subwoofer channel, that's one way of creating it, other amps can have that feature built in, or you can go full DSP.
    I used the two front speaker feeds, accessible under the passenger seat, (drivers seat in LHD) as that was the easiest place to run them from. also picked the front as the drivers up front are the bass speakers in the stock setup, I wanted as much signal as possible for the virtual subwoofer channel to use.
  9. #549
    Hi again MIG
    The BCM swap is a very big job, and not for the faint of heart, it evolves a lot of wiring, depinning and crimping, and you have the safety risk that if you did anything wrong, your lights might stop working.
    There are a few build logs with the CECM to BCM on the Passat, this would be similar if you want to gage the amount of work.
    The BCM is responsible for the terminal 58d (panel dimming circuit) this is also a CAN value that is broadcasted. I am unsure if the CECM broadcasts this on a different ID or at all
  10. #550
    Also some of the terminals change size, some wires are too short to repin etc.
    It's about an 8 hour job in a very unergonomic location.
    Had there been an easier solution available for me at the time I would not have done it.
    There is demand for the adapter and bear in mind it's one guy doing it in his spare time.
    My advice would be wait until you can get one from him, or get yourself ready for a lot of discomfort and potentially a car that won't work while you get through the BCM upgrade.
