Page 52 of 58 FirstFirst ... 2425051525354 ... LastLast
Results 511 to 520 of 580
Thread: Discover Media retrofit
  1. #511
    Jan 2024
    canada
    Quote Originally Posted by MIG View Post
    I have had one of these, it uses the steering angle sensor to approximate the high line lines, this is passive on the can network unlike the highline unit.
    so how come i can't get it to work then?? supposed to be an easy hook up, connect all the wires as per diagram and bam, supposed to work...well not in my case
    i mean everything else with the mib unit is spot on, all works except the camera.
    is it a matter of setting up some key adaptations in 5F module?? or just this particular camera just plainly won't work in my 6R.
    SO in that case i can just return it, and get the t-roc 2GD....part # that Kamold suggested....it's only $180 canadian on ailexpress
  2. #512
    Hmmm....... OK that makes sense - but I'm not sure what is meant by "approximate" high-line lines?
    No offense intended, but isn't this a bit like being "approximate" dead (meaning that either the high-line lines are displayed and usable, or they are NOT)?
    AND, if the high-line lines are displayed and usable on the low-line camera - why would anyone buy the seller's high-line camera option?
    Again, no offense intended in my request for clarification - I'm simply trying to understand these non-OEM cameras
  3. #513
    Mornington Peninsula, VIC
    No offense taken. These aftermarket cameras are interesting units, some have better than OEM picture quality, but as there is no way to calibrate or load parameters like the OEM units, so they have been made with a one size fits all. the lines move but might not show the path of the car 100% or the distances with the lines correct to the car.
    Still they are pretty good, am I probably would of kept mine, but I ended up pinching the video cable and breaking it.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
  4. #514
    Jan 2024
    canada
    Confirm that the following adaptation channel is set to 'FBAS':
    IDE03471-ENG126143-Vehicle configuration-RVC_video_input
    Also confirm with a multimeter that the camera is getting 12v.
    i checked, i don't have such parameter to choose in adaptation; now what??
  5. #515
    Jan 2024
    canada
    VPS should be disabled. That's only for OEM highline control module. Was worth a try.
    You don't have a PDC module so you need to disable PDC adaptations:
    ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A
    and these 3 are already NOT ACTIVATED....or as you call them DISABLED
  6. #516
    Jun 2024
    Richmond NSW
    Is this available?
  7. #517
    Pacific Paradise QLD
    Quote Originally Posted by Specisl View Post
    Is this available?
    ????????????????? Is what available The thread is about fitting the unit, not if its for sale
  8. #518
    Jan 2024
    canada
    ok so i got the T-roc 2GD 827 469 low res RVC, now what??? how do i hook it up
    i know where the blue wire goes, it goes to the reverse light and there is well as the blk and clear (which go to the blue connector)
    but there is another black connector that looks like the wires brown and purple would go into (don't know which wire goes to what pin yet), but WHERE does that connector plug into??
    and there is also a green/black wire that has a pin attached to it and DON"T know exactly where that one goes either....POWER maybe?? and if so is it constant power or SWITCHED power??
    i've attached some pictures of all this
    THANKS again in advance.
    Discover Media retrofit-image0-jpg
    Discover Media retrofit-image1-jpg
    Discover Media retrofit-image2-jpg
    Discover Media retrofit-image3-jpg
    Discover Media retrofit-image4-jpg
    Discover Media retrofit-image5-jpg
    Discover Media retrofit-image6-jpg
  9. #519
    This is how the power is connected:
    KL30=constant power
    KL31=ground
    Discover Media retrofit-rvc-low-wiring-jpg
  10. #520
    Jan 2024
    canada
    KL30=constant power
    KL31=ground
    so in my situation/application, which wire is the KL30 and which one is KL31
    i have a BROWN wire as well as a PURPLE wire which i assume they to to that black 2 pin connector, but i don't know which wire goes to which pin
    and then i have green with a black stripe wire that has a metal pin crimped to it and i DON"T know where that one goes either
    thanks.
