Page 50 of 57 FirstFirst ... 404849505152 ... LastLast
Results 491 to 500 of 567
Thread: Discover Media retrofit
  1. #491
    Jan 2024
    canada
    I want the entire long-code string - but if that isn't possible, gimme the status of Byte 19, Bit 4.
    there you go....
    Discover Media retrofit-bite-19-png
  2. #492
    hmm........... OK, clearly the software switch for the low-line camera is set. Assuming that this non-OEM camera (which surprisingly uses CAN high/low wires) is indeed a low-line camera- this should be OK.
    Check that the values for the 2 x adaptation channels below in the 5F module are set to not active:
    1. Car Function List BAP Gen2 → VPS_0x0B
    2. Car Function List BAP Gen2 → VPS_0x0B_msg_bus
    Also, check that the video-signal terminations on the QUAD lock connector for the coaxial cable is correct - meaning that the screen-earth wire (Black wire in the picture below) is connected to pin #12 and NOT to pin #6.
    Finally, if you still can't get the camera to work - maybe try telling the MIB that this is a high-line camera? I'm totally guessing of course and this is a "desperation" suggestion!! To do this, remove the tick from Byte 19 Bit 4 and set:
    1. Car Function List BAP Gen2 → VPS_0x0B > active
    2. Car Function List BAP Gen2 → VPS_0x0B_msg_bus > terminal 15, or comfort data bus, or infotainment data bus
    If ALL my suggestions above fail - I'm all-out-of-ideas!!
    Again, the problem with this equipment is that it's non-OEM, maybe the seller can help?
  3. #493
    Jan 2024
    canada
    and where do i find these adaptation channels to set them NOT ACTIVE
  4. #494
    From the VCDS Open Controller screen for the 5F Module - select Adaptation - 10
    In the Search box below, enter "ENG117712" and ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B should appear in the Channel (1B) box. If it doesn't, click on the down-arrow on the right-side of the Channel (1B) box and select the channel. Make the suggested change and press Do it! - follow the prompts to implement the change.
    Repeat for the 2nd channel by entering "ENG117713" into Search box
  5. #495
    Jan 2024
    canada
    when i type ENG117712 as you said in the search window and press enter, nothing happens
    and i see nothing in the drop down box
    Discover Media retrofit-nothing-happens-png
  6. #496
    Jan 2024
    canada
    so i checked both of those fields, and as you can see they were ALREADY NOT ACTIVATED. i did NOT have to change anything
    the RVC video cable is in the right spot as well, black at pin 12 and the other at pin 6
    i have also tried the other steps you suggested, make the 117712 activated and then the 117713 (using the 3 options you suggested, terminal 15, or comfort data bus, or infotainment data bus )
    and none of those combinations were of any success.
    Sorry to pick your brain over this...
    Discover Media retrofit-eng117712-already-not-activated-png
    Discover Media retrofit-eng117713-already-not-activated-png
  7. #497
    Jan 2024
    canada
    does anyone else have some suggestions on this???
    Kamold, what's your take on this?? should i ditch/return the camera i got from RCD330.com adn go for a 2GD T-ROC camera you suggested??
    thanks in advance.
  8. #498
    I would power the camera with an external 12v power supply and test that way first. Also try swapping the 2 pins on the camera input to the MIB.
  9. #499
    Jan 2024
    canada
    i already did that; my initial thought was that maybe the two pins were soldered wrong inside the camera so i swapped the pin 6 and 12 in the blue connector, but no dice
  10. #500
    Confirm that the following adaptation channel is set to 'FBAS':
    IDE03471-ENG126143-Vehicle configuration-RVC_video_input
    Also confirm with a multimeter that the camera is getting 12v.
