Page 49 of 57 FirstFirst ... 394748495051 ... LastLast
Results 481 to 490 of 567
Thread: Discover Media retrofit
  1. #481
    Jan 2024
    canada
    Discover Media retrofit-img_4958-jpgDiscover Media retrofit-img_4957-jpg
    This is where i hooked up the can + adn can - to the oem rns 510 quadlock as well as the black screen i get when i put the car in reverse
  2. #482
    Jan 2024
    canada
    Saturday,18,May,2024,16:55:13:11842
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 24.5.0.0 (x64)
    Data version: 20240429 DS355.0
    Ross-Tech: Home
    VIN: WVWPF7AJ2DW009721 License Plate:
    Mileage: 70000km-43495mi Repair Order:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
    56 62 72 77
    VIN: WVWPF7AJ2DW009721 Mileage: 70000km-43495miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    2E-Media Player 3 -- Status: Cannot be reached 1100
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CRZ) Labels:. 06F-907-115-CDL.clb
    Part No SW: 5K0 907 115 M HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0030
    Revision: 5BH21--- Serial number:
    Coding: 0403010A180F0160
    Shop #: WSC 85573 554 600234
    VCID: 346C150857152D3697-8060
    VINID: 9E69E058745A0949C00091C2047B2F8BA6
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
    Component: ESP MK60EC1 H31 0152
    Revision: 00H31001
    Coding: 144BE00C49228003281207E6921A0141310000
    Shop #: WSC 01357 011 00200
    VCID: 7DFAF02CE4DF2C7E28-8028
    Address 05: Acc/Start Auth. (J51 Labels:| 5K0-959-434.clb
    Part No SW: 5K0 959 434 B HW: 5K0 959 434
    Component: VWKESSYPQ35GP 085 0902
    Revision: 00085000 Serial number: 0175854123 Dataset Number: 5K0116v____ 5K0C
    Coding: 030C0C
    ASAM Dataset: EV_KESSYPQ35G A02013
    ROD: EV_KESSYPQ35G_A02_VW32.rod
    VCID: 346C15089F152D3697-8060
    Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
    Part No SW: 35D 907 044 B HW: 35D 907 044 B
    Component: Climatronic H03 0303
    Revision: 00001K02
    Coding: 0008002002
    Shop #: WSC 12345 123 12345
    ASAM Dataset: EV_ACClimaBHBVW411 A01001
    ROD: EV_ACClimaBHBVW411_VW36.rod
    VCID: 2648FF4059C94FA619-8072
    Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
    Part No SW: 1K0 937 084 J HW: 1K0 937 084 J
    Component: BCM PQ35 B 111 0709
    Revision: AB111709
    Coding: 61180ABF8CEB0EC4108800C170000B4448850486675D8DB0E4 8420248040
    VCID: 356A280C9C6F343EA0-8060
    Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
    Component: Wischer 18051 26 0512
    Coding: 009F95
    1 Fault Found:
    00061 - Footwell Lights
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 70008 km
    Time Indication: 0
    Date: 2018.10.09
    Time: 16:54:43
    Freeze Frame:
    Term 15 On
    Voltage: 12.15 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
    Component: AirbagVW10G 013 0724
    Serial number: 003GVRA2BYNS Dataset Number: 5K0003v__B_ 0069
    Coding: 00003132
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
    ROD: EV_AirbaVW10SMEVW360.rod
    VCID: 3F864A24A653FE6E7A-806A
    Crash sensor for side airbag: driver side:
    Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Fahr.V H02 ----
    Serial number: 3572MSME2F05756BZZZ1
    Front Passenger's Side Airbag Crash Sensor:
    Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
    Component: S.Sens.Beif.V H02 ----
    Serial number: 3582MSME61286066ZZZT
    Rear Side Airbag Crash Sensor (on driver's side):
    Component: S.Sens.Fahr.H --- ----
    Serial number: 3512QSME7E06153CZZZ$
    Passenger side rear thorax airbag crash sensor:
    Component: S.Sens.Beif.H --- ----
    Serial number: 3522QSME5C101565ZZZR
    Crash sensor for front airbag: driver side:
    Component: F.Sens.Fahr --- ----
    Serial number: 35527SME3651782CZZZK
    Crash sensor for front airbag: front passenger side:
    Component: F.Sens.Beif --- ----
    Serial number: 35627SME704B782CZZZS
    Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
    Part No SW: 5K0 953 521 BR HW: 5K0 953 569 E
    Component: LENKS.MODUL 014 0140
    Revision: FF010041 Serial number: 20120525301907
    Coding: 100A140000
    ASAM Dataset: EV_SMLSNGVOLWSXS A01004
    ROD: EV_SMLSNGVOLWS.rod
    VCID: 7DFAF02CECDF2C7E28-8028
    Multifunction steering wheel control module:
    Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H31 0033
    Coding: 820000
    Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 5K6 920 873 C HW: 5K6 920 873 C
    Component: KOMBI H05 0705
    Serial number: 00000000000000
    Coding: 370D00
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
    ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
    VCID: 36682F0089693F26A9-8062
    Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
    Component: J533 Gateway H42 1632
    Revision: H42 Serial number: 180512F2002532
    Coding: 350002
    VCID: 3F864A24AE53FE6E7A-806A
    1 Fault Found:
    03272 - Control Module for Audio Interface
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 70008 km
    Time Indication: 0
    Date: 2018.10.09
    Time: 16:54:46
    Address 22: AWD Labels: 0AY-907-554-V1.clb
    Part No SW: 0BR 907 554 C HW: 0BR 907 554 C
    Component: Haldex 4Motion 3018
    Coding: 0000005
    Shop #: WSC 00000 000 00000
    VCID: 458A58CC0C8FA4BE30-8010
    Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234 HW: 5K0 953 234
    Component: IMMO H05 0705
    Coding: 000007
    ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
    ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
    VCID: 6AD0CB708D51ABC6FD-803E
    Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
    Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
    Component: ELV-PQ35 H20 0240
    Revision: 00000000 Serial number: 12000114103003
    Coding: 4100000000000000
    ASAM Dataset: EV_ELVMarquMPVW36X A01001
    ROD: EV_ELVMarquMPVW36X_VW32.rod
    VCID: 2F661A6476330EEEEA-807A
  3. #483
    Jan 2024
    canada
    I HAD TO DO IT IN TWO PARTS BECAUSE I WAS EXCEEDING 10000 CHARACTERS
    Address 2E: Media Player 3
    Cannot be reached
    Address 37: Navigation
    Cannot be reached
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
    Component: Tuer-SG 009 2119
    Coding: 0001204
    VCID: 31621C1CA807181EFC-8064
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 P
    Component: EPS_ZFLS Kl. 251 3305
    Revision: 00H22000
    VCID: 377622044663C62EB2-8062
    Address 47: Sound System (R12) Labels: None
    Part No HW: 5K0 035 456 B
    Component: KonzernAmp 8K H07 0368
    Revision: -------- Serial number: EAA085A0027287 Dataset Number: 1K8050v____ 5K04
    ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
    ROD: EV_AudioVerst8KanalBNO1_VW12.rod
    VCID: 55AA888C342F143E40-8000
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
    Coding: 0001204
    VCID: 32601310AD01230685-8066
    Address 55: Headlight Range Labels: 5M0-907-357-V2.clb
    Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
    Component: AFS-Steuergeraet 0148
    Revision: 00H04000 Serial number:
    Coding: 1479708
    Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul l 0005
    Coding: 00000022
    Subsystem 2 - Part No: ID-R fehlt Labels: ID-55-02.CLB
    Component: AFS-Lst.-Modul r ....
    Coding: 00000255
    5 Faults Found:
    02234 - Right Headlight Power Output Stage (J66
    004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 59
    Mileage: 70008 km
    Time Indication: 0
    Date: 2018.10.09
    Time: 16:54:42
    Freeze Frame:
    Voltage: 11.93 V
    Speed: 0.0 km/h
    ABS 1
    01042 - Control Module; Not Coded
    000 - - - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Time Indication: 0
    Freeze Frame:
    Invalid
    Invalid
    Invalid
    02656 - Power Output Stage for Left Headlight (J667); Not Coded
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Time Indication: 0
    Freeze Frame:
    Invalid
    Invalid
    Invalid
    02657 - Power Output Stage for Right Headlight (J66; Not Coded
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 59
    Time Indication: 0
    Freeze Frame:
    Invalid
    Invalid
    Invalid
    01539 - Headlights Not Adjusted
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Fault Status: 11100101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 59
    Time Indication: 0
    Freeze Frame:
    Invalid
    Invalid
    Invalid
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
    Component: Tuer-SG 007 2101
    Coding: 0001168
    Shop #: WSC 01357 011 1012552
    VCID: 356A280C5C6F343EA0-8060
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
    Coding: 0001168
    VCID: 36682F0041693F26A9-8062
    Address 77: Telephone
    Cannot be reached
    End-------------------------(Elapsed Time: 03:00)--------------------------
  4. #484
    ^^^^ yes, the SCAN confirms that the Gateway module is unable to communicate with the modules on the infotainment CAN bus!
    However- given your latest scan, I'm not sure if the "cannot be reached" errors are due to the fact that these modules refer to the original factory modules that were replaced by the new MIB unit.
    I note that your SCAN does NOT report a module at the normal CAN address for a MIB (which is address hex5F) - but I assume that the MIB is operating correctly (other than the RVC operation). Lots of aftermarket MIB-lookalike non-OEM units avoid SCAN reports
    Normally, a MIB not appearing on a SCAN would be problematic - but because the infotainment set-up on this car is now very non-OEM, anything is possible. So it's anyone's guess how the SCAN is meant to report a healthy Infotainment CAN arrangement for the retrofitted MIB on this car!
    After viewing the full-SCAN, my gut-feel is now that this car might need to have its GIL (Gateway Installation List) adjusted - but again, the fact that there is NO 5F module in your SCAN and the MIB is working, makes me hesitant to suggest this option!!
    The other concerning issue is the RVC, itself - meaning that the non-OEM camera that you retrofitted is NOT like a normal OEM low-line camera
    You said in a previous post:
    Quote Originally Posted by RBmk6R View Post
    i don't want the fancy high res camera that the lines turn with the steering wheel turns...i want something basic like this low rec RVC
    Smoked black badge camera Dynamic parking line Golf6/7 GTI Polo EOS Beetle PassatCC RCD330 plus | RCD330 Plus | RCD340G
    An OEM low-line camera does NOT use CAN-high/low wires - it's a simple dumb device that hangs-off the MIB. The OEM high-line camera is the version that is connected to the CAN network!
    However, clearly the non-OEM camera that you installed DOES use CAN high/low wires, but I assume from your words above that it was sold as a low-line camera. So something is very different about the RVC that you installed - no surprise I guess because it's non-OEM equipment!!
    So bottom-line = it's possible because of the non-OEM MIB that you first installed that the "cannot be reached" errors in your SCAN might be a "red-herring" for the camera problem - maybe?
    I suggest that you try a couple of experiments:
    1. Remove the CAN high/low wires from their connections to the CAN network.
      • Cleae ALL errors and then make a fresh SCAN.
      • Do the same "cannot be reached" errors re-appear? If so, the SCAN errors result from the retrofitted MIB (i.e. the errors are dispositive to the RVC problem)
    2. Refit the CAN high/low wires
      1. Change the current status of Byte 19, Bit 4 (Rear View Camera (RVC) Low installed) on the long-code for the 5F module (the MIB). Does the image appear on the MIB screen when reverse-gear is selected?
    3. If the problem persists- post-up a copy of the full MIB long-code string and the values for the 2 x adaptation channels below:
      1. Car Function List BAP Gen2 → VPS_0x0B
        Car Function List BAP Gen2 → VPS_0x0B_msg_bus
  5. #485
    Jan 2024
    canada
    hi Don,
    thx for the reply
    so to answer your question, YES the MIB STD2 PQ +/NAV part #5C0 035 684 (that i installed in my mk6 R to replace the factory RMS-510) works just fine apart for the RVC not displaying on the screen when i put the car in reverse.
    i had someone program the MIB unit programmed with the options that my mk6r came with, dynaudio amp. etc, etc...and he asked me if i want the RVC enabled as well, i said YES as i was gonna get one later ON.
    and even before i had bought this RVC i was still getting the black screen when putting the car in reverse, and i think that is the case because the MIB is enabled taht way for teh RVC, even though there wasn't one installed.
    i bought this type of RVC as i've seen some videos or posts of someone that had bought one and it worked with his MIB unit.
  6. #486
    Jan 2024
    canada
    hey Don,
    so i cleared all codes and did another scan as per your recommendation with NO CAN lines connected. here's the LOG and what do you make of this?
    part 1 of 2....because i was exceeding the 10000 characters
    Monday,20,May,2024,11:31:58:11842
    Ross-Tech: Home
    56 62 72 77
    Revision: 00H31001
    Coding: 030C0C
    Revision: 00001K02
    Coding: 0008002002
    Revision: AB111709
    Coding: 009F95
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 60
    Mileage: 70008 km
    Time Indication: 0
    Date: 2018.10.11
    Time: 11:32:38
    Freeze Frame:
    Term 15 On
    Voltage: 12.45 V
    ON
    ON
    Term 50 Off
    OFF
    OFF
    Coding: 00003132
    Coding: 100A140000
    Coding: 820000
    Coding: 370D00
    Coding: 350002
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 60
    Mileage: 70008 km
    Time Indication: 0
    Date: 2018.10.11
    Time: 11:32:44
    Coding: 0000005
    Coding: 000007
  7. #487
    Jan 2024
    canada
    part 2 of 2
    Cannot be reached
    Cannot be reached
    Coding: 0001204
    Revision: 00H22000
    Address 47: Sound System (R12) Labels: 5K0-035-456.clb
    Part No SW: 5K0 035 456 B HW: 5K0 035 456 B
    VCID: 2952F47C48D760DE34-807C
    Coding: 0001204
    Coding: 1479708
    Subsystem 1 - Part No: ID-L fehlt Labels: ID-55-01.CLB
    Component: AFS-Lst.-Modul l ....
    Coding: 00000255
    Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
    Component: AFS-Lst.-Modul r 0005
    Coding: 00000022
    5 Faults Found:
    02233 - Left Headlight Power Output Stage (J667)
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 60
    Mileage: 70008 km
    Time Indication: 0
    Date: 2018.10.11
    Time: 11:32:39
    Freeze Frame:
    Voltage: 12.35 V
    Speed: 0.0 km/h
    ABS 1
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 60
    Time Indication: 0
    Freeze Frame:
    Invalid
    Invalid
    Invalid
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 60
    Time Indication: 0
    Freeze Frame:
    Invalid
    Invalid
    Invalid
    000 - - - MIL ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 60
    Time Indication: 0
    Freeze Frame:
    Invalid
    Invalid
    Invalid
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 60
    Time Indication: 0
    Freeze Frame:
    Invalid
    Invalid
    Invalid
    Address 56: Radio
    Cannot be reached
    Coding: 0001168
    Coding: 0001168
    Cannot be reached
    End-------------------------(Elapsed Time: 02:59)--------------------------
  8. #488
    Quote Originally Posted by dv52 View Post
    if the problem persists- post-up a copy of the full mib long-code string and the values for the 2 x adaptation channels below:
    car function list bap gen2 → vps_0x0
    car function list bap gen2 → vps_0x0b_msg_bus
    I need this info
    I'm not sure how you access this module given that it doesn't appear in your SCAN - maybe you can access the 5F module directly from this screen:
  9. #489
    Jan 2024
    canada
    I need this info
    i'm not sure either how i can access that module
    and even if i can access it, which BYTE and BIT you want me to access of the particular LONG CODE?
  10. #490
    I want the entire long-code string - but if that isn't possible, gimme the status of Byte 19, Bit 4.
