Originally Posted by
kamold
'How hard' is a very relative question...it's straight forward and well understood. If you're handy with tools including wiring and coding with VCDS/OBD11 then it's a straight forward retrofit.
Need to remove trim for the boot, along the sills and then up behind the dash to get to behind the head unit as well as power and ground, and trigger to reverse light.
You can use factory lowline flip badge 2GD camera from T-Roc which will give you static image.
If you want dynamic (moving guidelines) then your best bet is an aftermarket canbus flip badge camera.
You can't use an MQB highline camera unfortunately. They use different CAN messaging.
