Page 45 of 57 FirstFirst ... 35434445464755 ... LastLast
Results 441 to 450 of 567
Thread: Discover Media retrofit
  1. #441
    The digitizers unfortunately fail. Generally starts with top right of screen not responding properly to touch inputs.
    Eventually spreads and becomes progressively less responsive.
    The digitizers themselves are cheap but the replacement process is messy (have to heat and remove the optically clear adhesive which holds the digitizer onto the LCD) and runs the risk of cracking the LCD.
    FInd someone who repairs them, or you can buy a complete panel but this is more expensive.
  2. #442
    Feb 2020
    FRANCE
    Thanks Kamold for your reply.
    I am using MST2_EU_VW_PQ_P0480T firmware.
    I would like to test a firmware downgrade from 480T to 369T.
    When I want to downgrade, the MIB STD2 does not allow me to downgrade.
    It only allow a newer version of the firmware to be flashed.
    Is there any way to force the firmware downgrade (eg. from 480T to 369T) ?
    Thank you.
  3. #443
    Feb 2020
    FRANCE
    I managed to manually downgrade back to 369T using SWDL / Select All
    Quote Originally Posted by hector2001 View Post
    Thank you.
  4. #444
    Jan 2024
    canada
    so regarding clock display on the Discover, has there been a fix for this by now (with new firmware for the Disvover itself)so that the clock shows up properly or even to this day the issues is still the cluster??
    tanks in advance.
  5. #445
    Mornington Peninsula, VIC
    It’s the cluster that causes the issue, newer software on the cluster or modifying the eeprom of the cluster fixes the issue.
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
  6. #446
    Jan 2024
    canada
    Quote Originally Posted by MIG View Post
    how hard is it to update the cluster software and what program needs to be used?
    maybe i can get someone here in Canada to do it
    thanks.
  7. #447
    Quote Originally Posted by RBmk6R View Post
    thanks.
    Depends on what version the current SW and the part number of the cluster is, eeprom is not too bad if you find someone with the right tool, eeprom can be edited via OBD
  8. #448
    Jan 2008
    Camperdown, NSW
    the last map update was 2022/11/28. Is that it? or will there be more updates?
    I'm looking at this page:
    Volkswagen Map Updates
    GTI | MY08 | Blue Graphite | DSG | Leather | Bi-Xenon | RNS510 |
  9. #449
    Jan 2008
    Camperdown, NSW
    I've had a problem with my MIB2 for the last few weeks. During the day it dims (night mode) and when it's dark the screen brightens. I've seen a few other entries on the web about it suggesting to do a reset (done that) or it will just resolve itself eventually. Any one else experienced it and how did you fix it?
  10. #450
    Not sure if there will be another update. There should be.
    It does appear that all the maps for ALL navigation systems including MIB3 show latest maps as 11/21/2022. Not sure what VW are doing there.
    2024 maps are available to download here:
    Free download VW Audi Seat Skoda navigation maps
    The file for our AU maps is: DiscoverMedia2_MRM3_2010_V18
