Yes factory mic from RNS510 days.
MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
Genuine VCDS HEX-NET and VCP Pro
Nice post. Very informative.
I hoping you can help me with the following:
I am looking to upgrade the Gateway in my 2006 Mk 5 Jetta to the above Gateway version.
This I assume is required to run the 7N0907441B highline controller (which is my ultimate goal).
I have upgraded my Gateway a few times now by just swapping the module out and re-programming with VCDS.
I currently have a SW: 1K0 907 530 S (HW: 1K0 907 951) installed however I do happen to have a 7N0 097 530AS (HW: 7N0 097 530AN S1653 HH56) just lying around at home.
Firstly will the 7N0 097 530AS work in my car? (not game enough to just try without asking first)
My main concern it that the 7N0 version will screw up stuff like my parking sensors.
Secondly, how does one upgrade to BC or BL? Hopefully it can be done via VCDS.
Look forward to a reply when you get a chance.
Hi Kamold,
Regarding my above post, I just had a look around in the Mk5 Golf & Jetta forum and it seems the 7N0 gateway will work (you helped out in the "CAN Gateway Upgrade - Now nothing works!" thread).
So the only question remaining is "How does one upgrade the software to BC or BL? (with out changing to another module)"
A BC (HH56) gateway can be upgraded to BL or BR via VCP or ODIS.
VCDS can't upgrade module firmware.
Older gateways can be upgraded after having the SPI EEPROM replaced with a larger unit.
Hello,
After upgrading my Discover Media firmware from 369 to 478, the "Back" button (top right on the screen) does not respond anymore.
I have to use buttons (Menu, Phone, Nav, etc.) to exit from any current menu.
Except this, everything is working fine.
Does anyone has the same issue ? Any fix ?
Thanks
