Not sure if PDC is working yet as haven't tested but will check adaptation. Thanks for the additional information.
Are there any other wires I should take from the RNS510 connectors and bring across?
No there is no climatronics display.
RVC just needs to be coded in the Discover at byte 19 I think (RVC low) and make sure if you have PDC that it's also coded for RVC.
Do you already have PDC display working in the Discover? If not it needs to be enabled in adaptations. It's on infotainment databus.
MY12 Golf R | 5 Dr | Deep Black | DSG | Discover Media retrofit | RVC retrofit | DYNAUDIO
If you have a proper harness it should bring all the pins across to the correct location.
However the cheap Chinese ones don't have all the pins just the main power and speaker wires so you might have to end up bypassing the harness and plug the pins directly onto the connector block that plugs directly into the disco.
So to get PDC working I also had to do the following:
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
Also had to turn off RVC option in long coding as I don't have it installed yet.
So this is probably a dumb question but I have now installed my RVC and completed the VCDS coding. Camera works fine but OPS no longer appears.
I have seen screenshots where both appear on the screen at the same time. Is it possible to achieve this? Can the screen function be switched between camera and OPS on the fly?
Have I missed something obvious?
Thanks.
Need a newer PDC module
Ahh yeh I remember that from your original post now that you mention it again. Will investigate but guess I would need to find someone local with VCP to make the required settings change.
Any suggestions on the best place to buy the PDC module?
Is the PDC module located behind the drivers side rear wheel?
Thanks again.
PDC is in different locations in different vehicles. What is yours?
MK6 Golf R 2012
What's the part number of your current PDC module?
