cannot code the RVC module, it gives error "coding rejected" does it require any security access or sumtheng to code it?
And what about the problem with 5F module: the parkpilot is currently not available"??
Any adaptation or coding to consider?
I cannot code the RVC module, it gives error "coding rejected" does it require any security access or sumtheng to code it?
Try sa 20103 for rvc.
Yes there is adaptation required for park assist.
Take an adaptation channel map and post it.
Hey Kamold,
sorry for my late response, it took sometime from me to figure out how to export the adaptation channel map it is HERE. and SA didn't work either for 6C module! it is showing error: "Controller refused the key! Error35: Invalid key"
below is my full auto-scan for your reference
Dropbox - autoscan.pdf - Simplify your life
waiting for your feedback
Thanks.
Which input do you have your camera plugged into in the RVC module?
It still shows no video input.
gray plug: Camera to module
2 pin plug: camera to module
Brown cable: ground
Red cable: +12v
Orange brown and orange violet cables to CAN-+
White and black cables to MIB pins 6 and 12
The module is having grey, green plugs connected as well as the red big plug with multipin.
Hello Kamold, Do you know the camera that fits my golf mk6 without using a converter adapter? Passat CC and Golf mk7 sportsvan cameras are compatible, I wonder if you have information about this?
Here are the pinout differences:
Discovwer PQ Camera Pinout - Google Sheets
If you are connecting to a Discover Media, then you can use an aftermarket camera like this:
For VW VOLKSWAGEN Golf 6 7 MK7 MK6 Passat CC Polo Flip Logo Emblem Camera Badge Rotating Camera Dynamic Trajectory Line CCD-in Vehicle Camera from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
Hello Kamold I got my harness from the below link and I used it exactly as described by connecting the camera and module!!
VW Wiring loom reversing camera High Line Camera 7N0907441B Camera TIGUAN I, Sharan. VW Kabelsatz Rückfahrkamera High Line Kamera 7N0907441B Camera TIGUAN I, SHARAN. | eBay
Module is also purchased from this:
VW Passat cc Facelift 1.4 TSI Control Unit Rear View Camera Rfk 7N0907441B VW Passat cc Facelift 1.4 TSI Control Unit Rear View Camera Rfk 7N0907441B | eBay
Still black screen for two seconds and then "the parkpilot is currently not available".
Any Idea on how to test the camera itself and how to remove the error messege from 5F module.
I'm sorry to bother you that much but I really spent like a week trying to find a solution but with no luck.
