Page 19 of 58 FirstFirst ... 9171819202129 ... LastLast
Results 181 to 190 of 580
Thread: Discover Media retrofit
  1. #181
    Jan 2017
    Aside from everything else being perfect on my MIB2 retrofit, the clock on the unit no longer syncs with my phone - it's now always displaying 12:00, with occasional flashes of 6:28.
    I've tried deleting and re-setting up the bluetooth connection restarting the unit, but nothing seems to fix it.
    If anyone's had the same and fixed it, let me know!
  2. #182
    Clock should be getting the time over can from the instrument cluster.
    Have you tried turning it off and on again?
  3. #183
    Jan 2017
    Actually, you're right - AA/CP take it from the phone, but the clock on the head unit should be synced with the instrument cluster.
    I've tried resetting/rebooting it, also tried changing the time on the time on the instrument cluster to see it that triggers an update, but nothing seems to work... I'll thinking I'll have to plug it into VAGCOM and see if I get something there.
  4. #184
    Is there a summary for parts to look out for from the wreckers and how to complete the instal?
    2000 Audi S3 •
    |Revo Stage 2+ | Revo Select Plus| Custom 3" exhaust |
    |3" down pipe | 120cell High Flow cat | Forge Dump valve | |Wagner-tuning FMIC ||Big brake kit 355mm | coilovers |
  5. #185
    Quote Originally Posted by random101 View Post
    You want a discover media unit from an my16 Tiguan, MY16 Jetta, MY16/17 Scirocco R, T6 transporter or MY16/17 Caddy.
    5c0035680b/d/f (analogue radio)
    Or
    5c0035680c/E/g (dab radio)
    Has to have been only freshly removed from the donor vehicle and not powered up outside of the vehicle so as to not start running down the 8 hour CP lockdown.
    If it's already CP locked then there is additional expense to have CP removed and all feature enable codes restored to the unit.
    Then you need the custom patch board, quadlock adaptor harness, USB harness and port, maps sdcard and possibly some other upgraded parts depending on what car you have and what accessories are fitted.
  6. #186
    Truely amazing work!
    I’ll soon take delivery of my R36 10.5 - I’ll review it all then and see what we can do
    2000 Audi S3 •
  7. #187
    Oct 2017
    Hello Kamold,
    I successfully installed my vehicle this device. But I have 2 small problems.
    I use a can filter adapter and I have a 3D cluster. The adapter didnt have a USB connection. I found the correct pins connected and I started, but I could not find where to plug the Aux Pins.
    My aux switch has 4 pins I posted my aux pins photo.
    Second question
    I bought wrong navi sd card, installed maps are from other countries. Can I use it if I install my own country update?
    Tapatalk Pro kullanarak iPhone aracılığıyla gönderildi
  8. #188
    What do you want aux for?
    It's pretty much obsolete these days I would think?
    Aux pins are:
    T12j/2 (green)AUX/MDI Left
    T12j/1 (green)Aux/MDI GND
    T12j/7 (green)Aux/MDI Right
    Maps sdcard you can just format it and install the correct maps.
    There is a hidden partition that has the license in it.
  9. #189
    Oct 2017
    Aux pins are:
    Hello, thanks for your reply. I want to use completely this device Discover Media retrofit
    I am using this harness but it has 4 aux pins Discover Media retrofit 3 ok but 4th pins? Discover Media retrofit
    Let me ask you a few more questions when I find you. Where did you put the USB input in your car? I'm thinking of using the Jetta 5C ashtray console, but I do not know whether my car fits.
    My last question; My car is Golf Mk6, Can I apply Golf Mk7 rear view camera?
  10. #190
    For USB port you can get a generic aftermarket USB port for Golf and plug into the discover plug hidden behind.
    Yes you can use golf 7 camera, it requires some body panel cutting like mk6 camera in mk5.
    Aux pins you only need left right and ground. Not sure what the 4th pin is maybe just shielding?
