Page 14 of 57 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 567
Thread: Discover Media retrofit
  1. #131
    Dec 2014
    Monaro, NSW
    Quote Originally Posted by prdriscoll View Post
    Do others have this glitch or not have this glitch? Any ideas on whether this can be corrected?
    I have noticed this too. This is not just an issue with this system, but is the standard approach in most computer operating systems when a character is not available in a font set. I would suggest this is because the Discover Media head unit post dates the white MFD, therefore I guess the only way to fix it is to update to a colour MFD.
    Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
    Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
  2. #132
    I think it is supposed to be MHz.
    This is what it looks like with a colour MFD.
  3. #133
    Jan 2017
    For me, I'm missing what I assume is the battery symbol for both Android Auto, Phone and possibly CarPlay (don't use it, so don't know).
    Could also be a network strength icon, but meh, either way - tiny tiny tiny price to pay to have a 1000 times better system than the RCD510 that didn't display anything on the MFD!
  4. #134
    Mar 2018
    Buenos Aires
    Hello i have the same issue at first when reteofitting mib2 unit on mk6. It was solved after doing 2 things (don't know wich ot them solved it) unplugging media/bt module over the glove box and upgrading gw to have 5F module on installation list.
    I didn't have time for playing yet but i want to find the way to have nav info on mfd.
    I have pdc info and rvc low working properly. Mfd info is the only thing missing at moment.
    Hope it help you.
    Enviado desde mi SM-G935F mediante Tapatalk
  5. #135
    Jun 2018
    Morristown, NJ
    Quote Originally Posted by agustinfx View Post
    Hope it help you.
    Thanks for the replies everyone, and thanks for the pics kamold.
    agustinfx, are you saying you don't have the white square issue? Do you have any pics?
    Simo, I'm not sure exactly what you're referring to. But network signal and battery icons work fine on my unit and MFD.
    Separate question: there's no ringtone in the car when someone calls me with my phone connected via bluetooth to the Discover Media unit. I can't find any ringtone options either. Does anyone know anything about this?
  6. #136
    Mar 2018
    Buenos Aires
    Sorry i have no pics.
    I remember it perfect as you described when i was installing the unit.
    The white empty square went out when installing updated gw and unplugging media/bt module. I also have to do some wiring in bt module connector on the car side to get the bt mic working in mib2 unit.
  7. #137
    Jun 2018
    Morristown, NJ
    I also unplugged the bluetooth module and had to do some wiring in the BT module connector to get the mic to work as well.
    Do you know what revision your gateway is? I upgraded mine, but to the BC revision (7N0 907 530 BC). Maybe I need a newer one still.
  8. #138
    No that's new enough. It supports address 5f. I would think it has more to do with the cluster software version.
  9. #139
    Mar 2018
    Buenos Aires
    I upgraded from AM to BK with HW55
    I think your version is ok since you have 5F module on instal list.
  10. #140
    Jun 2018
    Morristown, NJ
    Hmm, you guys are probably right. To try to get to the bottom of this... do you know your instrument cluster SW/HW numbers?
    Here's mine from VCDS:
    Code:
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
       Component: KOMBI         H05 0705
       Serial number: 00000000000000
       Coding: 270D01
       Shop #: WSC 01357 011 00200
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
       VCID: 3753D7F08EA6F0FCE9-8062
