Page 12 of 57 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 567
Thread: Discover Media retrofit
  1. #111
    Good stuff.
    Sorry that's a mistake in my original post I will correct it.
  2. #112
    Apr 2009
    The Little Red Dot Singapore
    Hi Kamold,
    I was hoping to save the Highline Camera set up and obtained a AV-Adapter Interface. Problem is, there is no wiring instructions for it. Looking thru the net, it seems that these av-adapters are only for the lowline camera which have 5 wires to the RNS vs the highline 11-wires set up on the 26pin connector.
    You mentioned that it is possible. Any pointers on this ?
    Failing which, I would have to revert to a Lowline camera set up.
  3. #113
    Quote Originally Posted by cbx750p View Post
    Hi Kamold,
    The only way you can get highline to work is by using the Tiguan 7n0 highline rvc module.
    If you just use a rgbs to cvbs adapter the head unit will try to talk to the older rvc module and fail.
  4. #114
    Apr 2009
    Okay. Got it ! Think I will have to forego the Highline camera. No point spending more $$$. Will install the Golf 7 SportsVan camera instead.
  5. #115
    They aren't that expensive.
    But you need to run a new harness as well.
    If you have highline ready you don't want to go backwards...
  6. #116
    Jan 2017
    So, I picked up an adapter harness to switch from the earlier model PDC to the newer one... Any idea why one plug on the adapter cable has an empty plug in it, with some nonsensical chinese writing on it?
  7. #117
    Quote Originally Posted by Simo View Post
    Show me a picture I can't remember exactly off the top of my head...
  8. #118
    Jan 2017
    Thanks Kamold...
    I tried a google translate, but it made no sense at all!
    Discover Media retrofit-img_20180528_184137-jpg
    The black plugs are identical, save the writing and the empty plug in one of them, so I know it's something important
  9. #119
    I seem to remember having to rework it slightly....
    And it's a bit fiddly because there isn't much room to play up there.
    I think you have to cut the ziptie that's on the factory harness plug and swap it for the blank one you have there because it's a different shape?
  10. #120
    May 2018
    Buenos Aires
    Hi, my name is Diego, I am from Argentina and I Have a Volkswagen Suran, itīs a latinoamerocan model, like A Golf Variant
    The car Have the Discover Media Stereo and I trying to activate the rear camera Module (I bought the 7N0 907 441 B) but I have some errors.
    Those are the errors
    Friday,25,May,2018,12:03:49:00006VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.2.0.3
    Data version: 20180212 DS287.0
    www.Ross-Tech.com
    VIN: 8AWPB45Z9GA512179 License Plate:
    Address 6C: Back-up Cam. Labels: 5Q0-907-441.clb
    Control Module Part Number: 7N0 907 441 B HW: 7N0 907 441 B
    Component and/or Version: VW428 RVC Mid H04 0040
    Software Coding: 000000002201000300
    Work Shop Code: WSC 12345 123 12345
    ASAM Dataset: EV_CamSysRearPANAVW428 002002 (VW21)
    ROD: EV_CamSysRearPANAVW428.rod
    VCID: 306FA6C26B2355C4A8-8064
    4 Faults Found:
    10490624 - No End-of-Line Programming
    B2013 00 [009] - -
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 150
    OFF
    9591827 - Video Signal Line
    B125C 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 150
    OFF
    9661201 - Cable for Video Signal from Rear View Camera
    B136B 11 [009] - Short to Ground
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 150
    OFF
    10489856 - No Basic Setting
    B2010 00 [009] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 150
    OFF
    And this is the a part of Autoscan, I donīt know if the Can Gateway is compatible or need to activate something more.
    Friday,25,May,2018,12:02:24:00006VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    www.Ross-Tech.com
    Mileage: 28300km-17584mi Repair Order:
    Chassis Type: 5Z-VW21 (7E0)
    Scan: 01 03 04 09 10 15 17 19 25 44 5F 6C
    VIN: 8AWPB45Z9GA512179 Mileage: 28300km-17584miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: Malfunction 0010
    Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
    Part No SW: 7E0 937 089 HW: 7E0 937 089
    Component: BCM PQ25 MMI4 H80 0733
    Revision: BB080001 Serial number: 0772 254151282
    Coding: 3AA98B3A4C3BC600113A06C06CC89A80B080629D6084200024 0580020000
    Shop #: WSC 79157 025 435844
    VCID: 70EF66C2A3A315C4E8-8024
    Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
    Component: RLS 090915 05 54 0403
    Coding: 0030AD
    Subsystem 2 - Part No SW: 5Z0 959 800 A HW: 5Z0 959 800 A
    Component: ZFH_4T H08 0015
    Serial number: 3982FL00001510050028
    Coding: 006B54
    Subsystem 3 - Part No SW: 5Z0 959 800 A HW: 5Z0 959 800 A
    Coding: 006B54
    Subsystem 4 - Part No: 5Z0 951 171 E
    Component: DWA-Sensor 00 004 0008
    Coding: 000000
    Subsystem 5 - Part No SW: 18D 959 442 HW: 18D 959 442
    Component: E221__MFL-YLG H01 0110
    Serial number: 000000000A0074290715
    Coding: 200000
    Subsystem 6 - Part No SW: 5Z0 959 800 A HW: 5Z0 959 800 A
    Coding: 006B54
    Subsystem 7 - Part No SW: 5Z0 959 800 A HW: 5Z0 959 800 A
    Coding: 006B54
    No fault code found.
    Address 10: Park/Steer Assist (J446) Labels:* None
    Part No SW: 5Z0 919 475 A HW: 7N0 919 475
    Component: PARKHILFE 8K H06 0003
    Revision: -------- Serial number: 67781516900036
    Coding: 100003
    Shop #: WSC 00001 001 00001
    ASAM Dataset: EV_EPHVA18VW23X0000 001002
    ROD: EV_EPHVA18VW23X0000.rod
    VCID: 4385F90ECA95DE5C45-8016
    Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
    Part No SW: 7E0 909 901 HW: 7E0 937 089
    Component: GW-K-CAN TP20 H80 0733
    Revision: BB080001
    Coding: 002203
    VCID: 68DF0EA29B73DD04B0-803C
    Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
    Part No SW: 5C0 035 680 B HW: 5C0 035 680 B
    Component: MU-S-N-ER H22 0245
    Serial number: VWZAZ2R8881661
    Coding: 02730203BE00000011220001011828001F0100C40020010047
    Shop #: WSC 00059 790 00014
    ASAM Dataset: EV_MUStd4CTSAT 001022
    ROD: EV_MUStd4CTSAT_VW21.rod
    VCID: 204F56823BC3E54438-8074
    Data medium:
    Subsystem 1 - Part No SW: 3G0 919 866 BM HW: -----------
    Component: MRM2 2018 --- 0915
    Serial number: --------------------
    1 Fault Found:
    0518 - Front Right Treble Speaker
    B1064 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 150
    Mileage: 28302 km
    Date: 2027.14.29
    Time: 11:59:03
    Voltage terminal 30: 12.5 V
    Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
    Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
    Component: VW428 RVC Mid H04 0040
    Shop #: WSC 12345 123 12345
    4 Faults Found:
    B2013 00 [009] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 150
    OFF
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 150
    OFF
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 150
    OFF
    B2010 00 [009] - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 150
    OFF
    End-------------------------(Elapsed Time: 03:0--------------------------
    Regards!!!!
