Page 10 of 58 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 580
Thread: Discover Media retrofit
  1. #91
    Jan 2017
    VCDS Scan after putting the 3C0 Gateway back in:
    Interestingly the Immobiliser still has a fault reading, but I assume this is because I didn't clear the faults before re-running the scan.
    Code:
    Monday,07,May,2018,21:43:42:38493VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 36 42 44 46 47 52 53 55
              56 62 65 72 77
    VIN: WVWZZZ3CZAE038764   Mileage: 94960km-59005miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Sporadic communication error 1000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: Sporadic communication error 1000
    62-Door, Rear Left -- Status: OK 0000
    65-Tire Pressure -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: Not registered 0001
    Address 02: Auto Trans        Labels: 02E-927-770.clb
       Part No SW: 02E 300 012 E    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     440 1982
       Revision: 04844002    Serial number: 00000906161234
       Coding: 0000020
       Shop #: WSC 44551 111 44551
       VCID: 120555150DF9DCD4BE-8046
    No fault code found.
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-H.lbl
       Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
       Component: Bordnetz-SG     H54 2602
       Revision: 00H54000    Serial number: 00000003285402
       Coding: E6868F0700041A00470A00000F000000000A59435C000120000000000000
       Shop #: WSC 05124 000 00000
       VCID: 334BF09152A335DCD5-8066
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 300709 022  0601
       Coding: 00046997
       Shop #: WSC 05124
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     260809 046  0204
       Coding: 00208933
       Shop #: WSC 05124
    Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
       Part No SW: 3C8 919 475 A    HW: 3C8 919 475
       Component: PARKHILFE 8K  H07 0009
       Revision: --------    Serial number: 08740921503229
       Coding: 100103
       Shop #: WSC 12345 123 61029
       VCID: 3245F5956DB93CD4DE-8066
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0030
       Revision: 00032000    Serial number: 3C5953507CN
       Coding: 0001211
       Shop #: WSC 05314 000 00000
       VCID: 74C9338D172D72E40C-8020
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: E0221           002 0030
    Address 17: Instruments (J285)       Labels:| 3C8-920-xxx-17.clb-SRI1
       Part No SW: 3C0 920 872 E    HW: 3C0 920 872 E
       Component: KOMBI         H02 0206
       Serial number: 00000000000000
       Coding: 160F00
       Shop #: WSC 05314 115 00000
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
       VCID: 277314C15E7B497C79-8072
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
       Part No SW: 3C0 907 530 L    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 3300P098270529
       Coding: FDA3FF07100202001003
       Shop #: WSC 11111 111 45725
       VCID: 2A75EDF58569741466-807E
    3 Faults Found:
    01304 - Radio
                004 - No Signal/Communication - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 184
                        Mileage: 94962 km
                        Time Indication: 0
                        Date: 2012.09.26
                        Time: 16:41:53
    01320 - Control Module for Climatronic (J255)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 184
                        Mileage: 94962 km
                        Time Indication: 0
                        Date: 2012.09.26
                        Time: 16:56:31
    01044 - Control Module Incorrectly Coded
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 144
                        Mileage: 94967 km
                        Time Indication: 0
                        Date: 2012.09.27
                        Time: 00:00:36
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3C0 959 433 AM    HW: 3C0 959 433 AM
       Component:    IMMO         052 0383
       Revision: 00052000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 75CF0E891C576BEC3B-8020
       Subsystem 1 - Part No: 3C0 905 861 G
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    1 Fault Found:
    02823 - Requirements for Locking the Steering Column Lock not met
                000 -  -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 184
                        Mileage: 94963 km
                        Time Indication: 0
                        Date: 2012.09.26
                        Time: 00:30:28
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
       Component: Sitzverstellung     1101
       Revision: 00005000    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 2F43FCE1BE8B113CB1-807A
    Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
       Part No SW: 1K0 959 701 AS    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1502
       Revision: 71009005    Serial number: 00000934398701
       Coding: 0005047
       Shop #: WSC 05311 000 00000
       VCID: 7F23ECA12E6B21BC61-802A
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 143    2901
       Revision: 00H17000
       Shop #: WSC 02069 000 90108
    Address 46: Central Conv.        Labels:. 3C0-959-433-46.clb
       Component:    KSG PQ46 RDK 052 0412
       Coding: 00910A0001860E76300494157008DFCE105801
       Subsystem 1 - Part No: 1K8 951 605
       Component: LIN BACKUP HORN H09 9002
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
       Part No SW: 5K0 035 456     HW: 5K0 035 456
       Component: KonzernAmp 8K H06 0340
       Revision: --------    Serial number: BP218198613822
       ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
       ROD: EV_AudioVerst8KanalBNO2.rod
       VCID: 67F354C19EFB897CB9-8032
    Address 53: Parking Brake        Labels: 5N0-907-801.clb
       Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
       Component: J540 EPB3  VW-15417 0007
       Revision:   010       Serial number: 00000000006790
       Coding: 0000057
       VCID: 2C79EBED8F9D6A2494-8078
    Address 56: Radio
    Cannot be reached
    Address 65: Tire Pressure        Labels: 3C0-959-433-65.lbl
       Component:    RDK              0453
       Coding: 0161211
    Address 77: Telephone
    Cannot be reached
    End-------------------------(Elapsed Time: 01:54)--------------------------
  2. #92
    Yes you will need to clear the fault for immobilizer and see if it comes back.
    For the OPS display, you will need to put the 7N0 gateway back in and then check the following adaptation channels in 5F infotainment:
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A - change to "activated"
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus - change to "Terminal 15"
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering - change to "Available"
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus - change to "Terminal 15"
    ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc - change to "Activated"
    ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill - change to "Activated"
  3. #93
    Jan 2017
    I have a hunch my OPS display issue might be an adaptation question...
    According to this, there's an adaptation setting for OPS at ID 313, but that looks like it's MFD display; as well as some other Park Assist settings at 641 and 642 which I'm guessing might need to be enabled.
    Looks like it might be a swap back to the 7N0 CAN and give it a go...
    BTW - if anyone is interested, there's some half decent info on the MIB2 units here - almost a user manual, but not quite.
  4. #94
    Jan 2017
    Ha! thank Kamold - looks like we were both onto the same thing - except yours looks like some comprehensive answers, whereas I'm just stabbing around in the dark.
    I'll give these a go
  5. #95
    Jan 2017
    Because I really didn't want to go through the whole process of my dash apart and swapping the gateways over, I thought I might see if I can still access the head unit through the 3C0 gateway...
    Surprise, surprise, while I couldn't select it from the installed list, or add it to the gateway, I could access the 5F address directly, do the adaptions and any long coding (although there was none of that to do).
    The unit appeared to accept all adaptions (restarted everything, checked the values, and the adaptions reported the appropriate changes), although still no parking display...
    Now I'm confused - is it possible these adaptations didn't really go through (because of the wrong gateway). If they didn't then why did the changes persist after restarting the car and VCDS?
    Of course if I got my parking display up, I would have been pretty chuffed by the whole result. Sadly not the case.
    Kamold - what are your thoughts? I'm leaning towards something else being missing - I'm convinced these adaptations went through via the old gateway.
  6. #96
    Try coding the first 2 bytes of your 5F infotainment:
    Current: 0284
    New: 0274
  7. #97
    Jan 2017
    Current: 0284
    New: 0274
    Dang. No luck...
    I have a theory, which I'll try out on the weekend.
    While I still have the old gateway connected, the steering wheel, MFD and reverse switch (volume lowering works) are all talking to the headunit, even though it's technically on an unknown address: 5F. I figure this is because they did their handshake with the new gateway installed, and now know how to talk to each other.
    OPS on the other hand, was not set up with the right adaptation in the head unit with the new gateway, so never did the initial handshake, and therefore can't communicate.
    Solution - swap the new gateway back in, perform the handshake, then swap it back out. Voila.
    Ok, it's just a theory, but it's the only one making sense to me right now.
  8. #98
    The new head unit is responding to the CAN commands on the infotainment bus same as an older unit at address 56 would. It can see a signal for mute, reverse, volume up etc.
    There is no handshake as such in CAN. Just messages on a series of buses which connect and are filtered via the CANbus gateway.
    I've never actually actually done any work with a Composition Media unit. I am only making assumptions based on what works in Discover Media.
    2 ideas: It may be that the PDC messages are not being passed by the 3c8 gateway correctly - this is easily confirmed by testing with the 7N0 gateway in place.
    Failing that it may be that you need a 1k8 PDC module like the Composition Media unit is supposed to see in a factory configuration like in an MY16 Jetta or Tiguan...
  9. #99
    Jan 2017
    No luck with the 7N0 Gateway and original PDC, so it looks like I might need to upgrade to the 1k8 PDC. Hopefully this also works with the 3C8 Gateway - I'd rather give up the OPS display than have to do everything else that required with the 7N0 Gateway.
    Interestingly, I can't find anywhere that specifically says you need the newer PDC for OPS to work (unless, as mentioned in this thread, it's to enable the camera overlay). Even the stores selling retrofit kits mention nothing about OPS.
  10. #100
    I had a chat to a friend about this and this seems to be the sitation:
    3C8 (and also 3AA) PDC modules with Discover/Composition media only show OPS IF you also have a RVC. This is just some sort of compatibility oddity.
    I had a 3c8 module with rvc and discover. Since upgraded it to 1k8 and then PLA 2.0
    1K8 PDC module will allow you to have only OPS or RVC image with OPS overlay.
    I know 1k8 works with just OPS as MY16 Jetta has this combination from factory.
    1k8 PDC module requires a 3 connector to 2 connector adapter harness.
