Originally Posted by
scobb
I just played with this a bit more. Turns out that a USB pen drive connected to the MDI interface does work in the way I would expect it to i.e. remembering what the last media input selected was and restarting a music track where it left off. So it's just the USB hard drive that is misbehaving.
Both devices are formatted identically as FAT32 devices, so I'm at a loss as to why one works correctly and one does not.
scoob: Idle is certainly correct in identifying current drain as a potential issue. However the problem may alo be related to the memory capacity of the USB facility.
Have a read of the table on page 26 of the Discover Media manual (at least this is the correct page on my version which is for a "my13" model). The table says that there are memory limits on the USB facility. If you have a bog standard SDHC stick, your limit is 32GB. If you are using a more up-to-date SDXC stick, then you have a limit of 2TB. I'm assuming that the HDD is the older type magnetic drive so timing problems and access speed will almost certainly be problematic. It's interesting to speculate whether a Solid State Drive would work, but it's probably better to just buy a SDXC stick.
