Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: DEALER FITTED RNS510 - Does the MFD display instructions
    Feb 2010
    Lane Cove, NSW
    I have been in a mate's Tiguan fitted with a factory RNS510. He pointed out that the MFD shows sat nav instructions as well as the RNS510 itself.
    If a dealer fits the RNS510 will the MFD display that same info as the factory fitted model?
    (I promise I did numerous searches but couldn't find a definitive answer)
    tornado red GTI MkVI, 5dr, DSG, Sat Nav, RVC, MDI.
    Red Honda Fireblade Red Cooper S (SOLD)
    Jun 2009
    Apparently they will have the same function so long as they are compatible versions i.e. A/B/C
    Feb 2010
    Canberra
    Quote Originally Posted by Tux View Post
    (I promised I did numerous searches but couldn't find a definitive answer)
    Dealer fitted RNS 510 from memory will not work with the directions displayed on the MFD .. Mind you this is only from memory.. Also no voice functions.
    Phillip Fairhall
    Brand Manager
    Rolfe Renault / Audi Centre Canberra
    Melrose Drive Phillip ACT
    Feb 2010
    Lane Cove, NSW
    Does anyone know whether it will be the same as 'factory fitted?'
    Apr 2009
    Mine shows up on the MFD???! I definitely didn't buy mine from the factory!
    Genuine VW Parts Importer | Navigation | Bluetooth |
    Repairs | Lighting | Coding | Programming |Cameras
    Mar 2010
    Lost
    Has to be enabled Via VCDS. so if the dealer is lazy and doesnt enable it, it wont.
    I fitted mine, and enabled it myself. nice feature IMO
    More opportunites have been lost from indecision, rather than wrong decision....
    Oct 2009
    Just out of interest, can the knock off RNS510s on fleabay display directions in the MFD?
    Aug 2009
    South Australia
    There is no difference between factory fitted and dealer fitted except for the placement of the antenna.All units should integrate seamlessly so long as your car is relatively recent.I have a ebay RNS510 B unit and it integrates perfectly with the red MDF. I think you will need a C unit if you have a white MFD/DIS. Don't know if a older A or B will work with a white MFD.l It will display direction and data in the MFD and voice overs .(From my memory even before coding with vcds)
    Jan 2008
    Yes it will. There is absolutely no difference between the installs except that you won't have a roof mounted GPS antenna which makes little difference in the operation of the unit but otherwise you have an identical "experience".
    Feb 2010
    Canberra
    Happy Days.
    Phillip Fairhall
    Brand Manager
