Results 1 to 4 of 4
Thread: Dash cams
    Adelaide hills, SA
    Dash cams
    For sure it can’t be the 5 best dash cams for 2019, though I like the last one in this video.
    Pacific Paradise QLD
    Yes the Waylens might be good but nearly all the rest are unknown Chinese stuff and as far as Garmin goes Yeah right
    The BV DR650 is at least 3 years old and has been superseded by at least two models. The 119 is also an Ok camera
    As for the Waylens one Read here
    Waylens Secure360 Review | DashCamTalk
    https://www.amazon.com/Waylens-Secur...ews/B07DLLD95C
    Waylens Secure360 WiFi Car Security Dash Camera Review | Digital Trends
    Maybe a flawed design with good intentions
    As for the Garmin
    Garmin Dash Cam 55 | ProductReview.com.au
    I wonder sometimes about these Youtube reviewers as some spruik rubbish and even one Commercial installer advocates stuffing wires down the side of fuses to power them
    There is no perfect dashcam but basically the Streetguardian, Viofo, Blackvue and one Thinkware are noted as being probably the best camera brands
    Dec 2006
    Kilsyth, VIC
    We have two of the Viofo A119's, one is still working perfectly although the newer one seems to have issues with it's GPS unit. I'm not sure if I've had a couple of poor power supplies which have dies or if the GPS unit is killing the power supplies, but if I plug poewr directly into the unit it works flawlessly (albeit with no speed or location data (and no time sync).
    For the cost of these units I'm considering just buying a new one and being done (maybe the dual camera version this time). It's really getting to the point where I don't know why everyone wouldn't want a dash cam installed.
    I'd like to see car manufacturers do one of two things. Either:
    A) Include cameras as standard in the car which can be used for this purpose with the addition of a memory stick.
    or
    B) Include a power socket (USB?) near the head lining to make installation pretty idiot proof. (same story for phone mounts, I'd like to see a power socket in the A Pillar given the insanely common use case).
    Quote Originally Posted by The_Hawk View Post
    or
    One small problem is that not all dashcams run on USB and /or 5v would need to have both that and 12v
    They will come standard eventually no doubt and would be best if wired so that they can record to a HDD somewhere in the car as it then would have a much longer recording capacity Also have battery pack to allow a longer parking mode
