Results 1 to 9 of 9
Thread: DAB+ module for 2016 Golf Alltrack
    Jan 2013
    Hobart Tasmania
    Can anyone advise if the MIB II unit in a 2016 Alltrack can have a DAB+ module installed ?
    I understand there is an option for the Discovery Pro to have a DAB+ module installed, but the Pro was was not offered as an option on the 2016 Alltrack at the time of purchase.
    Any advice would be appreciated.
    Cheers.
    My16 Golf Alltrack, DAP
    MY18 Golf Comfortline
    You would need a different Discover Pro unit (the thing in your glovebox) that has the DAB tuner and antenna connector in it, otherwise you'd need to go something aftermarket.
    Apr 2015
    It sounds like the Discover Pro is the only OEM way to go about it, if you where thinking of going aftermarket Kogan is currently offering some sweet EOFY deals including this : https://www.kogan.com/au/buy/kogan-d...dio-converter/
    Has an Aux passthrough so you dont loose for factory input, and looks small enough that you could mount it just about anywhere and quite neatly to, given all the cables connection are mounted on the one side
    2004 MK4 R32 - Reflex Silver - KW V3 - AdvanSport V105 - Colour Matched RCN210
    2012 up! 3Door - Tornado Red - More details soon…
    Jan 2013
    Hobart Tasmania
    Would I need to replace the 6.5" screen with a component matched 8.0" as well ?, I suspect just replacing the glovebox unit wouldn't work as they would need to be a matched pair.
    No the screen is dumb. If you were going to upgrade the mib however you'd be crazy not to upgrade to the 8 inch screen
    It is much nicer
    Jan 2013
    Hobart Tasmania
    It is much nicer
    Yes I agree, a bigger screen would be nice, just wondering how complex the upgrade would need to be just to get dab+ and what it would cost. Is it a simple plug and play glovebox upgrade, or do you need to run a new antenna and recode the system?
    Needs a dab antenna which sits next to the a pillar on passenger side windscreen. Coding is required unless the unit is preconfigured by the seller.
    Jan 2013
    Hobart Tasmania
    Thanks
    Apr 2017
    belgrave victoria
    Lot of effort just get a 7.5
