Results 21 to 30 of 34
Thread: Constant buzzing/static noise coming from speakers - Help required
  1. #21
    That message is normal when you reboot. There is no missing software.
    The Dynaudio splash screen at boot is a coding option only. Everyone can turn that on if they want. Doesn't affect operation.
    That fault does not affect operation in any way. You just need to put in a 'valid' workshop code. 12345 is 'valid'.
    Post a screenshot of your current coding on your RNS.
  2. #22
    Feb 2015
    S.E burbs Melbourne
    Thanks Horace,
    I have been meaning to get to the forum but ran out of time over the weekend.
    Thanks also for spending the time to go through all the different permutations.
    Cheers!
  3. #23
    Jan 2014
    Mt Martha, Vic
    No worries. Let me know when you want to come over and we 'll have another go and get some screen shots posted.
    Using Tapatalk
  4. #24
    Feb 2015
    S.E burbs Melbourne
    See you tonight Horace.
  5. #25
    Feb 2015
    S.E burbs Melbourne
    Hi Kamold,
    We ended up taking a lot screen shots. I have attached a few that maybe relevant but pls let me know if you require anything else.
    I also have the logs but will PM (if you prefer) as they are quite lengthy.
    Here is summary of the scan:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 22 25 2E 36 37 42 44 46 47
    52 53 55 56 62 65 69 72 77
    VIN: Mileage: 48650km-30229miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    Here is a screenshot of controller 47. We could not access this menu
    Attached Thumbnails Attached Thumbnails Constant buzzing/static noise coming from speakers - Help required-47-jpg
  6. #26
    Feb 2015
    S.E burbs Melbourne
    Logs of malfunctions:
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
    Component: RNS-MID H06 5238
    Revision: AB001001 Serial number: VWZ6Z7K8131060
    Coding: 00050000010000800000
    Shop #: WSC 12345 123 12345
    VCID: 377D0E1086CAF2999F5-8062
    Subsystem 1 - Part No: 7L6 919 859 G
    Component: AUNZ V8 8207
    1 Fault Found:
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 102
    Mileage: 48656 km
    Time Indication: 0
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Coding: 00050400000000800000
    1 Fault Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 48
    Reset counter: 102
    Mileage: 48408 km
    Time Indication: 0
  7. #27
    Can anyone with Dynaudio post their RNS long coding string?
    I won't be able to look at this until tomorrow.
  8. #28
    OK so looks like your coding is wrong.
    Mainly byte 1 should be coded to 07 for Dynaudio DSP
    Constant buzzing/static noise coming from speakers - Help required-dynaudio-jpg
    I think it should be this string:
    0007040001000000090000
    Note that this doesn't take into account other options like RVC etc
  9. #29
    Jan 2014
    Mt Martha, Vic
    What is RVC?
    I thought BAP was only required if the navigation info was not displaying on the cluster display? (Its all displaying as it should)
    Using Tapatalk
  10. #30
    Reverse Camera.
    Yes there is a setting for BAP protocol for MFD display.
    Additionally the Dynaudio amp in the Passat is controlled over the CANbus. The lower spec Dynaudio in the Golf is the same as the stock amp in the R36.
