Thanks Horace,
I have been meaning to get to the forum but ran out of time over the weekend.
Thanks also for spending the time to go through all the different permutations.
Cheers!
That message is normal when you reboot. There is no missing software.
The Dynaudio splash screen at boot is a coding option only. Everyone can turn that on if they want. Doesn't affect operation.
That fault does not affect operation in any way. You just need to put in a 'valid' workshop code. 12345 is 'valid'.
Post a screenshot of your current coding on your RNS.
Thanks Horace,
Cheers!
No worries. Let me know when you want to come over and we 'll have another go and get some screen shots posted.
Using Tapatalk
See you tonight Horace.
Hi Kamold,
We ended up taking a lot screen shots. I have attached a few that maybe relevant but pls let me know if you require anything else.
I also have the logs but will PM (if you prefer) as they are quite lengthy.
Here is summary of the scan:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 25 2E 36 37 42 44 46 47
52 53 55 56 62 65 69 72 77
VIN: Mileage: 48650km-30229miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
Here is a screenshot of controller 47. We could not access this menu
Logs of malfunctions:
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5238
Revision: AB001001 Serial number: VWZ6Z7K8131060
Coding: 00050000010000800000
Shop #: WSC 12345 123 12345
VCID: 377D0E1086CAF2999F5-8062
Subsystem 1 - Part No: 7L6 919 859 G
Component: AUNZ V8 8207
1 Fault Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 102
Mileage: 48656 km
Time Indication: 0
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Coding: 00050400000000800000
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 48
Reset counter: 102
Mileage: 48408 km
Time Indication: 0
Can anyone with Dynaudio post their RNS long coding string?
I won't be able to look at this until tomorrow.
What is RVC?
I thought BAP was only required if the navigation info was not displaying on the cluster display? (Its all displaying as it should)
Using Tapatalk
Reverse Camera.
Yes there is a setting for BAP protocol for MFD display.
Additionally the Dynaudio amp in the Passat is controlled over the CANbus. The lower spec Dynaudio in the Golf is the same as the stock amp in the R36.
