Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Constant buzzing/static noise coming from speakers - Help required
    Feb 2015
    S.E burbs Melbourne
    Unhappy Constant buzzing/static noise coming from speakers - Help required
    Hi All,
    I did a couple of firmware upgrades over the weekend and ended up at 5238. Since doing so I have a constant buzzing/static sound coming from my speakers. I have read on another forum that there is a TSB (not sure what this stands for) fix for this issue. Can anyone please advise if they can help?
    Starting to think I should have left all well and good alone.
    Cheers,
    Shayne
    First just try a hard reboot of the RNS by pressing Setup + Eject + Info...
    Feb 2015
    S.E burbs Melbourne
    Have tried both a soft and hard reset but to no avail, the noise still remains.
    Do you have an MDI, or anything plugged into the aux port?
    If so unplug any devices/cables from these accessories.
    Feb 2015
    S.E burbs Melbourne
    I have an MDI but nothing plugged into the cable. Have yet to use it as my plug has a lightning (from memory) adaptor and hence doesn't fit the cable adaptor that came with the car.
    Nevertheless appreciate your help and keep the suggestions coming, hopefully we stumble onto something.
    Mindarie, Perth (WA)
    can I ask...where did you get the 5238 version from? (as in website/link etc).
    Tinnitus?
    Was the RNS factory fitted or retrofit?
    If retrofit, I would remove the unit, and reseat the quadlock connector and test.
    When you say a couple of firmware updates, what exactly did you do and what version did you start from? Did you have any issues with any of them?
    Feb 2015
    S.E burbs Melbourne
    Quote Originally Posted by FJ Steve View Post
    Hi FJ, I followed the 52xx link in firmware update for RNS510 thread on the first page.
    Feb 2015
    S.E burbs Melbourne
    Quote Originally Posted by Polo GTEye N9 View Post
    Tinnitus?
    I could very well be developing a case of!
