1. 7F0 is a Transporter part number. 1T0 is a Golf/Passat part number.
The hardware is essentially the same, depending on the revision.
2. You can update your unit to the same generation of firmware. You will need to reload your maps from the maps CD:
Firmware updates for RNS510 units in Australia/NZ
3. Once you update the firmware and correctly code the unit for voice control it will essentially be the same as what you had. The replacement one is older. The list of variants is here:
Volkswagen RNS 510 Part Number List | my-gti.com
