He Crackerz
Did you find the problem as I seem to have the same. Lately the reception has just been very poor.
Hi,
The other day my Columbus RNS510 started to have poor radio reception. I've looked in the forums for help and found that there could be an antenna issue but when I go into the FM diagnostics it shows that both antennas are connected.
Will it still show that if the antennas aren't functioning correctly?
It seemed to happen around the time I drove over a small tree branch/twigs (soft) that caught under the car. Stopped fairly soon after to remove. Just wondering if static build up could have caused this?
Any ideas what to test and how? I've borrowed a VCDS which I'll put on tonight and see if that shows anything.
He Crackerz
2011 T5 Mulitivan Comfortline 103kw ,2009 Golf Tdi Comfortline 103kw,2005 Golf Mk5 GTI Stage 1 220BHP (UK),2004 Golf GT TDI 140BHP (UK),1995 Golf Mk3 GTI 120BHP (UK), 1980 Escort Mk2 RS2000(South African), 1980 Opel GTE 148Kw (South African), 1979 Golf Mk1.
No, still not great. I need to check against the other car. Haven't had time to muck around with it.
Best to take out the unit and check the cables are in ok and not corroded. Check fuses. Check cables to antenna.
Other thing I though of was to attach a another antenna to see how that goes.
All trial and error i'm afraid.
Will give it a go.
Thanks 👍
