Page 16 of 27 FirstFirst ... 6141516171826 ... LastLast
Results 151 to 160 of 268
Thread: Collection of POI's
  1. #151
    Jan 2012
    Epping, NSW
    I have noticed the past couple of days ( maybe coincident with V6 map upgrade) that the camera poi are doubled up, with one being about 30 metres out from the other, e.g look at Blaxland Rd Eastwood red/speed cam...
  2. #152
    May 2011
    Cronulla, NSW
    Quote Originally Posted by aussietig View Post
    You need to download and load the PersonalPOI.db3 via SD Card instead (if you want my cameras).
    You've actually loaded the optional file. The SD card file is actually mandatory if you want all my POIs and especially cameras.
    Basically not possible to append 173 categories into the map. But can do so via SD Card.
    Also ... nobody normally searches for cameras as a destination. So didn't bother adding them to the POI.db3 file.
    Hope that makes sense to people.
    Ahh fantastic. Thanks for the additional information, I had no idea I needed to load both set's of POI's (I incorrectly presumed the large POI.db3 included everything). I'll load up an SD card and give it a shot!
    Thanks again
    Skoda Octavia RS TSI Liftback MY11 - Race Blue
  3. #153
    Feb 2013
    Wollongong NSW
    Quote Originally Posted by technopato View Post
    Thank you aussietig for taking the time out and putting these POI's together!
    Ive uploaded to my RNS and they work like a charm!
    +1 thank you aussietig for your hardwork, much appreciated
  4. #154
    May 2007
    aussietig
    I must be missing something here with the PersonalPOI and POI.db3.
    My understanding of your earlier post was your PersonalPOI works fine but searching won't work as we expect. So in order to get searching to work we use your custom POI.db3 and put that into a map update, then use the PersonalPOI ontop and we have your POI's searchable.
    I did that, but the POI is greyed out (as is select map detail), so nothing is searchable. (note this is the first thing I tried and its to late to do again) I'm not sure if the default maps + personalPOI works for me, but I'll give it a try tomorrow.
    Have I misunderstood this? What should be the outcome if I used custom map + the personalPOI? At present no POI are displayed, nothing can be selected. But maps + navigation seem to be fine.
    (using 4120 fw from other thread, 7120 map with 163928kb poi.db3, 18776kb personalpoi.db3)
  5. #155
    Jul 2010
    Quote Originally Posted by pomme View Post
    aussietig
    Slightly incorrect. PersonalPOI will work with any map (V4.1 and above) and will allow you to search for my POI.
    However, RNS510 will not include my custom POI categories in say a "tell me what POIs nearby" type of search.
    In other words, when you don't actually know where you want to go next and want the unit to give you suggestions.
    Handy when say you're visiting a new town or city; or can't remember the name of the place (but know that it's nearby).
    But if you always know what POI category (of mine) you're after, then no need to go to the trouble of loading the POI.db3 file. Just load the PersonalPOI.db3 file only, select the category from the 'Personal' folder and the unit will return the nearest locations for that particular custom category.
    Essentially I'm duplicating as much as the unit can handle into the Master list on the stock map with my custom POI.db3 file. So that it can also include my custom POI categories in a random search of all POIs nearby.
    Now if you've loaded all my files (and the file sizes you've listed looks correct), then I don't know why it's not working.
    But did you mean map version 7920 being the V6 map (instead of 7120)?
    Also there's absolutely no chance you've edited both my files or attempted to add your own POIs to it?
    From my experience, there's a limit to the number of custom POIs the unit can handle and unfortunately I don't know what that magic number is and have had to test that limit through trial and error.
    That is, painstakingly adding and deleting categories until the buttons aren't greyed out.
    So to me ... the greying out on your unit suggests you've somehow crossed that limit.
    Worse case, I recommend just loading the stock V6 map (with original POI.db3), together with just my PersonalPOI.db3 (if things get desperate).
    MY11 Tiguan 147TSI (SOLD)
  6. #156
    May 2007
    Thanks for the reply tig.
    Yea no idea why it wasn't working... might have been to do with going back to 4120 firmware. I know the original firmware was in the 5xxx range. I did use all your original files... only tried it that once... POI greyed out...
    Anyway, i acquired and installed the 5128 firmware (4120 was fairly laggy in comparison to 5128 for me)... original maps and just used the personalpoi. Works like a treat. Many thanks.
    I'll just miss out on the search... but thats not a big issue I think. Speed cameras is what I really wanted... but I'm running with BP and Shell servos on too which is a nice bonus.
  7. #157
    Jan 2008
    Camperdown, NSW
    When I try to install POI Inspector, I get an error from Trend saying it contains spyware.
    RNS510poi.exe
    GTI | MY08 | Blue Graphite | DSG | Leather | Bi-Xenon | RNS510 |
  8. #158
    Jul 2013
    hey great thread..
    Are you meant to get a Map CD with the new car ? as i bought a new VW with a RNS510 installed but i did not get a CD.
    I'm really keen on Speed Camera's as my tomtom has this feature and i really like it.
    2013 Alltrack | Icelandic Grey | Sunroof | Sports Pack
  9. #159
    Re: Collection of POI's
    Quote Originally Posted by kcv01 View Post
    hey great thread..
    Yes you should get a CD. I hassled the dealer for mine. It was obsolete but you ate still entitled to it.
    Sent from my HTC One using Tapatalk 2
  10. #160
    Jun 2011
    Has anyone got a more up to date sets of POIs than aussietigs (over a year old now) back on Page 3?
    Collection of POI's
