Quote Originally Posted by vraptor View Post
Do these include the updated trapster cams?
No. I've just stuck with POIDB.com as only source.
As you'd appreciate there's already enough categories to refresh as is.
Too time consuming to compile and re-compile from various sources.
---------- Post added at 10:11 PM ---------- Previous post was at 09:52 PM ----------
For those who want to add or modify icons on my POI files and are seeing no change on the map.
If you are changing the ones on the PersonalPOI.db3 file, then make sure you're selecting those to be displayed.
My guess is you've somehow selected the ones from the POI.db3 that sits within the 'Categories (Alphabetical)' or vice versa?
But this is assuming you've loaded both my POI files (one via SD and other via modified map).
I've definitely not locked the files. Wouldn't know how to anyway!
The other thing I can think of is you've somehow not rebuilt the database within POInspect0r, after your changes.
Try clicking 'vacuum current DB' under Tools menu (once you're happy with the changes).
