Nah, I don't think so. I have added a few to Aussietig's PersonalPOI.db3 without any drama, by following the process I noted above.
EDIT - sorry, that's a reply to the previous post, not vraptor's above.
No. I've just stuck with POIDB.com as only source.
As you'd appreciate there's already enough categories to refresh as is.
Too time consuming to compile and re-compile from various sources.
---------- Post added at 10:11 PM ---------- Previous post was at 09:52 PM ----------
For those who want to add or modify icons on my POI files and are seeing no change on the map.
If you are changing the ones on the PersonalPOI.db3 file, then make sure you're selecting those to be displayed.
My guess is you've somehow selected the ones from the POI.db3 that sits within the 'Categories (Alphabetical)' or vice versa?
But this is assuming you've loaded both my POI files (one via SD and other via modified map).
I've definitely not locked the files. Wouldn't know how to anyway!
The other thing I can think of is you've somehow not rebuilt the database within POInspect0r, after your changes.
Try clicking 'vacuum current DB' under Tools menu (once you're happy with the changes).
MY11 Tiguan 147TSI (SOLD)
SUCCESS!!!!! I've now changed some of aussietig's icons, and added some POI's of my own.
Thanks Swallowtail! Not that I need directions, but this afternoon I'll light up Dan Murphy's POI's then head over there to get a case of Cricketers Arms Lager with which I can toast your very good health. Thanks again mate.
I'm still using the old POI uploaded (not upgrading maps until the speed limit data is fixed) - I've noticed a couple of Shell petrol station icons show up where I know there to be no stations at all. One nearby was a little off. I could upgrade my PersonalPOI file but have to find my SD card reader first.
Wasn't expecting that - will actually have to find my SD card now![]()
Like I said ... my latest refresh (among other things) is an update of all cameras and petrol stations via the POIDB.com website.![]()
is it possible to use Tomtom Speed cam databas ?
