![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
aussietig
Ok ... problem with maps is that unit still recognizes you're still installing the same v4.1 map (CD_7492)
In other words ... it's not a new map according to the unit and so won't do anything with it.
You actually need to change the disk name to something different (e.g. CD_7493)
Bit of a pain if you don't have POInspect0r.
So quickest way is to load an older map (e.g. V3 or V4 map) onto your unit HDD first.
Then it will recognize your modded V4.1 map.
That should work!
![Thumb](https://www.vwwatercooled.com.au/forums/images/smilies2/thumb.gif)
When I read your post I thought "that's logical"
What I failed with was to advise in my original post, that the DVD was showing up as "error" and wouldn't load. Since your post....I downgraded back to V3 maps, then tried to load the POI modified V4.1....still the same result.
I'm using my usual method...using IMGburn as the software, slowest speed possible, same brand DVD/R as previously used (successfully). hmmmm.........
