Its still a handy function to have. Not everyone (ok well most people do) has a smartphone or knows how to find things with it.
Being able to navigate to a POI such as a petrol station when you're running low on fuel (and maybe don't have phone reception) or police station, other POI I think is a good feature.
Granted the cameras are the main feature most are interested in but I think its a noble cause nonetheless to get a good database of other POIs established. Just my 2c![]()
Had another crack at it!
This time, limited my merging of custom POIs with original POIs to just the 'Categories (Alphabetically)' folder and the POI functionality didn't crash and seem to have overcome the limit problem!
So what I've ended up with is all 118 categories still imported into RNS510 as 'PersonalPOI.db3' via SD Card.
And then most of the 118 categories (excluding CAMERAS folder) merged with the original v4.1 map's POIs in the above mentioned folder and re-installed as a modified v4.1 map (named CD_7493 as suggested).
Wasn't entirely according to plan ... but happy nevertheless that my efforts this weekend have paid off!
Have updated post #21 above with new links, if people want this as well!
MY11 Tiguan 147TSI (SOLD)
Nice work, I'll definately be using them![]()
THanks to both of you for all your work
If i already have the 4.1 maps installed, and now i want to replace the POI.DB3 with yours aussietig then how do I do it? I modified the ISO and replaced the POI.DB3 with your one and burnt the ISO but the RNS510 doesn't seem to be detecting anything new to install?
Situation:
Version C RNS510; FW2760; Map V4.1
I've downloaded the POI's (linked above) and replaced the .db3 file of the V4.1 map. I've re-burned the the 4.1 contents with the updated POI.db3 file to a new DVD (@ 1 x speed).
Unit fails to fall in love with the new map.
Question:
Will this process only work with FW 3970??
Ok ... problem with maps is that unit still recognizes you're still installing the same v4.1 map (CD_7492)
In other words ... it's not a new map according to the unit and so won't do anything with it.
You actually need to change the disk name to something different (e.g. CD_7493)
Bit of a pain if you don't have POInspect0r.
So quickest way is to load an older map (e.g. V3 or V4 map) onto your unit HDD first.
Then it will recognize your modded V4.1 map.
Another alternative is to just reformat (i.e. delete) the whole HDD partition that the original map is on using this .nrg file (burnt to a disk): https://docs.google.com/open?id=0B4H...VY1X2JQeWVrS1E
All your other HDD partition will remain intact (like music). However, remember to enable SW downgrade first via the secret menu, to install this map HDD partition reformat (as it's built under old FW 2720).
That should work!![]()
Last edited by aussietig; 19-08-2012 at 02:02 AM. Reason: Alternative method posted up
