Page 8 of 27 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 268
Thread: Collection of POI's
  1. #71
    Thanks for your help FJ Steve.
    I have now got the disk out after a couple of goes. I am back to Version 4.1 as I am now too scared to reinstall.
    No points of interest as I never got them to work either way.
    So after 4 days I am no furtheer then I was before.
    I think I will just give up.
    I guess you could say
    The german - 1
    The Spikeyboy22 - 0
  2. #72
    Mindarie, Perth (WA)
    Quote Originally Posted by spikeyboy22 View Post
    The german - 1
    The Spikeyboy22 - 0
    Did you read post #66?
    Put a general "please help" out there to the Melbourne crew. Someone should/could be able to help.
  3. #73
    Quote Originally Posted by FJ Steve View Post
    Yep tired it but still no luck.
  4. #74
    Melbourne, Vic
    Spikeyboy22, the filename and directory structure on the SD card must be perfect, otherwise the RNS-510 won't recognize the .db3 file, and hence the button will remain grey. I fell for this. I ended up exporting directly from poiinspector to SD card and then it worked fine.
    I think the structure on the SD card has to be,
    /personalPOI/personalPOI.db3
    2010 Candy White Golf GTI 5Dr. Manual, RNS-510, Bluetooth, Tints, GT-CX 18 Gloss Black Rims.
  5. #75
    Jul 2010
    Have updated most of my POI categories (especially cameras and petrol stations) via the POIDB.com website.
    Total POI categories is now 119 after adding Rebel Sport.
    So my links contained in post #21 are now to revised versions of both the PersonalPOI.db3 & POI.db3 (V5 map) files.
    NOTE: Have not bothered to update the POI.db3 (V4.1 map) file however.
    MY11 Tiguan 147TSI (SOLD)
  6. #76
    Jul 2010
    Robina Gold Coast
    Was going along the M4 today and decided to click on the map,The speed limit was also 120KPH how can this be ,i wonder if you get pulled over for speeding and blame the RNS 510 for getting booked ??
    Just read this in another forum any ideas ?
    maybe because 7679 is not final version??
    7703 Is final for AUS/NZ
  7. #77
    Jul 2010
    Quote Originally Posted by jords View Post
    Well ppl just aren't following the instructions properly.
    Have now made this step no.1 within the first set of instructions.
  8. #78
    Jan 2012
    Earlwood, NSW
    Quote Originally Posted by aussietig View Post
    Speaking of confused. I've been going around in circles for a while now. I still cannot load my own .db3 file. I can load aussietig's, but cannot add to it, or change anything in it using POInspector. If I choose "Edit category" in POInspector and select my own icons the new icons will appear on the PersonalPOI list on the satnav POI selection screen, but the icons on the map itself remain the same. I get it that the folder icon has changed, but the data in the file hasn't, but how do I change the POI icon on the map.
    My own POI build seems to load. The satnav tells me that filespace is used on the drive, and that I have several thousand POI's, but when I select "PersonalPOI" on the screen it just "blips" and nothing happens.
    aussietig's database is pretty comprehensive, but I'd like to at least be able to add some of my own POI's from GPS Data Team, or change some of aussietig's icons. Ideally I'd like to load my own POI database. If anyone has the patience to give me some "For Dummies" type clues I'd appreciate it.
  9. #79
    Feb 2009
    Quote Originally Posted by BottomScratcher View Post
    I had the same thing - I wanted to change aussietig's PersonalPOI.db3... I changed some icons, and whilst they changed on the list, they did not change on the map. What I did was export the category in POIInspector, then clear it out, delete it, and add a new category with the icon I wanted, and re-imported the previously exported POIs. That then successfully used the new icons.
    Adding new categories in pretty simple in POIInspector - d/l POIs from POIDB or similar, then create new category, import, give it an icon, and voila...
  10. #80
    Apr 2010
    Maybe he's exceeding a built-in limit of categories.
