Collection of POI's
Firmware 3xxx and above allows you to make your own POI database on an SD card, and then load it onto the unit. Where before, you would have had to write a new disc each time you wanted to upgrade the POI, you can now just delete the copied database from the RNS, and load a new one on.
Aussietig's collection, he's done a great job collating various POI sources...
Collection of POI's - Page 3
Video instructions on how to turn the specific POIs on in your map display thanks to Liquidforce are here:
Collection of POI's
For more details on upgrading the firmware, or using POInspect0r, see kamolds thread...
Custom POIs with 3xxx firmware, Aus/NZ Maps v 4.1 and POInspect0r
Or have a read of...
https://www.dropbox.com/s/lucuk3t63f...Guide_v1.0.pdf
Also if you choose to share, try to upload in one of the 4 file types that POInspect0r can import, those being... asc, gpx, ov2 and kml, or in db3 format.
Reason: As this is the first post in this section, just tidied it up for first time visitors.
- You may not post replies
- You may not edit your posts
Forum Rules
