Originally Posted by
aussietig
There is a limit to how many Poi unit can accept.
Still trying to work out that magic number.
After loading my file, you might need to reboot your unit to force it recognise the new poi. So need you to confirm how many did you load.
Or try redownloading my file and try again.
I t can only accept a maximum of ten categories to display on the screen. You can load as many as you like (within your .db3 file) IIRC, but when you select which categories you want displayed on the map...then 10 is the magic number.
+1 for resetting the unit.
Also...what is the size of your .db3 file Easter?
