Page 13 of 27 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 268
Thread: Collection of POI's
  1. #121
    Re: Collection of POI's
    Nice one thanks for the update!
    Sent from my HTC One X using Tapatalk 2
  2. #122
    Dec 2012
    Sydney, Australia
    WOW! thanks Aussietig and Kamold for putting so much great work into this.
    I've just downloaded the personalpoi.db3 and will have a go at loading them via SD card tonight.
    small question. I am a bit shaky on how to do the proper searchable install via CD.
    am I right that I need a V5 maps CD to begin with? then take an iso of it, replace the poi.db3 with aussietigs file then install that? but since my car is already v5 (I think, just bought novemeber 2012 scirocco R) I need to downgrade to 4.1 first AND I need to do something in the secret menu?
    where I'm going... is there possibly a sydney member who has a current map disk who can help me out with this over the next few weeks? I'm willing to travel to you and would be happy to provide a meal/drink/whatever in exchange for your time. I'm not particularly lazy, just not experienced with this stuff and don't want to balls it up.
    I'm also trying the VIM mod which seems a bit simpler so I'm giving that a go myself. fingers crossed!
  3. #123
    Upgrade to 4120 firmware from this forum, it has VIM already, plus maximises music partition and has secret menu enabled.
    Happy to help you out if you want a guide.
    No need to downgrade to 4.1, if you install new firmware there will be no map installed, so you can just install the v5 map that has poi file replaced as you mentioned.
  4. #124
    Dec 2012
    Sydney, Australia
    thanks for the reply kamold. I just logged on after coming upstairs from doing the VIM and uploading the personalpoi.db3.
    I just installed the VIM hack CD and at first it was working then it came to a screen where it said it couldn't 'downgrade' as current software was (for example) v1234 and disc inserted was v1234. but it then said insert a disc with later software or restart. it had ejected the disk at this point. I left the disc sitting there and did a reset (pressing eject, star and guide) and it then swalled the disc but up and started over again but this time I got the confirmation screen, clicked ok and it worked.
    is it possible I have 4120 firmware already? the car is pretty new (picked it up just 4 weeks ago so I guess maybe a few months old).
    if that's the case what's my best option? and also, what's the 'secret menu' and how do I enable it?
    sorry for the noob questions and thanks for your help.
  5. #125
    Apr 2010
  6. #126
    Dec 2012
    Sydney, Australia
    Hold Setup for ~30 seconds
    thanks Ryan_R. seems I am quite the noob...
  7. #127
    Apr 2010
    We've all been there. Once the Mk7 reaches us it should reset the playing field again
  8. #128
    Dec 2012
    Sydney, Australia
    I've got a small update people may or may not know about. I know tig posted about how if you just import the POI's via SD card you can't search for them. but you can still do a proximity search like "closest 7-11". I just went into nav, new dest, search, poi, chose category 'personal' then I put something like nearest dan murphy's and it works just fine. I guess maybe it doesn't work doing a complete search but if you know the thing you want to find it works nicely.
  9. #129
    Jun 2012
    Maroochydore, QLD
    Hi guys,
    A couple of videos on how to upload the POI from SD card and how to Mark them so they stay on the map
    - upload POIs from SD card
    - mark the Speed Cameras so they appear when you travel
    Hope it helps to some of us who have struggled with these features.
  10. #130
    Feb 2013
    Basingstoke
    Rns 510 icons
    Quote Originally Posted by Swallowtail View Post
    I had the same thing - I wanted to change aussietig's PersonalPOI.db3... I changed some icons, and whilst they changed on the list, they did not change on the map. What I did was export the category in POIInspector, then clear it out, delete it, and add a new category with the icon I wanted, and re-imported the previously exported POIs. That then successfully used the new icons.
    Adding new categories in pretty simple in POIInspector - d/l POIs from POIDB or similar, then create new category, import, give it an icon, and voila...
    Hi, I've tried to use my own icons, with the 34x39 and while the list show the new icon, it doesn't reflect on the map, how do I get the icons to show on the map. I've deleted everything and exported via poinspector but it still doesn't seem to work. I must be missing something but cant seem to figure it out, please help
