Results 1 to 10 of 14
Thread: Clueless Girl! Pls Help! Winca Headunit Error "application platform.exe" error
    Unhappy Clueless Girl! Pls Help! Winca Headunit Error "application platform.exe" error
    Hi,
    I have an aftermarket stereo unit for my VW Golf R32. It has been going good until this morning I got this error "application platform.exe encountered a serious error and must shut down". I can't do anything anymore. The radio itself is still playing the last selected radio station from yesterday but thats about it.
    Does anyone know how to get rid of it?
    I've attached a photo of my unit.
    Clueless Girl! Pls Help! Winca Headunit Error "application platform.exe" error-img_6466-jpg
    Thank you so much for your time!!
    I forgot to mention that I've had this pop up before (once every couple of months). Usually i'd just turn it off and then on and it would disappear.
    Last night my car battery nearly died (car could not start by itself, once I turned it on, the car needed revving to charge it back up). I think this may have caused the error.
    Pacific Paradise QLD
    Quote Originally Posted by queenina View Post
    Hi,
    Try holding down the two top left buttons and the very right hand one (at the same time for 10secs) which should reset the unit
    The ones on each side of the DVD slot are the ones I mean
    Thanks,
    I tried it out though and to no luck, it didnt work =(
    NSW, Sydney
    Hey queenina,
    Have you changed the Canbus? Have you checked to see if there is any loose connections at the back of the unit?
    Jan 2013
    Is this chinesse rns? One of my friend has same issue. Fix was: new canbus and upgrade firmware. I know all this done by vw specialist.
    Good luck.
    Sent from my D6503 using Tapatalk
    2014 Passat Wagon, TDI, blue-motion technology, ComfortPower front seats, Adaptive Damping Control, Premium Sound System, Power Tailgate, Sports pack
    Quote Originally Posted by robbie View Post
    Hey queenina,
    Hi Robbie,
    No I haven't changed it, I don't think anything would be loose.
    Thanks for the suggestion.
    Quote Originally Posted by saint70 View Post
    Good luck.
    Thanks saint70,
    I was told by my mechanic it was purchased from China. My mechanic is away for a few weeks and I was hoping there was an easy fix I could do because it is annoying me. Would you know where I could download the firmware?
    Jan 2013
    I got mine (original) from poland. Upgrade firmware done by vw service. For yours i really do not know since is not original. Wrong firmware can damage whole unit. So, better check model no before do anything. Regards
    Mindarie, Perth (WA)
    This is not an RNS510. It is a Chinese clone, running a Windows CE platform. Firmware developed by Continental and VW will not do anything positive to this unit, more than likely, will damage it.
    You need to find out/recall what generation WinCE platform the system was/is using and (maybe) reload that firmware.
    GPSUnderground.com could be a source, or speak to the previous owner of the vehicle (if you know who it was).
    Finally, if all else fails, could be time to upgrade to a more serious touch screen GPS Headunit (Viz, Alpine, Pioneer or VW OEM - RNS510).
    Jul 2007
    Brissy
    Have you tried disconnecting the battery ? Or if that is too technical, maybe locate the correct fuse and pull that.
    After a few minutes reconnect, this may force it to reboot and be all good again.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
