Results 1 to 2 of 2
Thread: Cig/ACC socket not working T5.2
    Jun 2011
    Just a quick technical question regarding fuses in the T5.2.
    My gps was plugged into my cigarette lighter and when unplugging it yesterday the end cap that holds the gps plug fuse came apart releasing a small spring that started to earth itself out inside the socket. This has led (to the best of my knowledge ) to the socket now not working so I figured the fuse must have blown. Which fuse is it in the panel? as my manual has nothing except a rear socket listed. Also is the cig/acc socket supposed to have power all the time or should it disable when the ignition is off? Mine always stays on.
    Cheers guys.
    Banjo
    Adelaide hills, SA
    Look in the maintenance sticky, the fuse could be at the same place as in T5's.
    It is normal that the acc socket has power all the time.
