Songs play at random
I originally had my media SD card playing the songs in Album form but now all the songs play all the number 2 songs from each album then number 3 and so on and I can't seem to be able to get the songs back into their separate albums
Ive tried every thing but there must be a way to get them back to the way they are stored on the SD card .
Have you named them in the order you expect them to play? A file system (well, the FAT/NTFS/other common file systems) don't have an inherent "order" per-se, so files are often parsed in order of filename.
If you're just wanting songs to play in order within a directory, you can try prefixing your filenames with the track number (eg 01_xxx, 02_xxx, etc).
Beyond that, it may be possible for the unit to use the Track Number field within the id3 tag of an mp3... although that's head-unit dependent and I don't know if the RNS-510 or RCD-510 support it.
- You may not post replies
- You may not edit your posts
Forum Rules
