Results 11 to 20 of 23
Thread: Charging Batteries in modern vehicles
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by warrick View Post
    hi
    i would like to get a CTek charger for use on my 2011 3.6 cc.with the battery in the boot is it safe to use with the battery connected? would the MXS 5 be a suitable choice? i use the car only a couple of times a week usually and only one of those is a reasonable run.
    cheers
    warrick
    They are designed to be used with the battery in place so no issues there. I was watching a video about the MXS 5.0 being used in a BMW with a rear mounted battery, the guy connected the charger to the terminals under the bonnet to charge the battery in the rear. So yeah, I think you'd be right.
    Interesting in my reading (and the guy from the shop said as much) the CTek units are rebranded and used by a bunch of supercar companies too. A few bits of talking here and there about supercar owners buying CTek branded unit for a fraction of the cost of the Bugatti branded one
    Erskineville, NSW
    hi
    cheers
    warrick
    That's the whole idea of a C-Tek. You attach the Comfort Connect terminals to the battery as a once-off and you can leave the charger plugged in if the car is sitting in the garage for days / weeks.
    I would have recommended the MXS3.8 but the MXS5 is better (possibly / probably).
    I recently set up a neighbours ride-on mower at his farm with an MXS3.8. He's only at the property every 3-4 weeks & the battery was discharging. He was concerned that the technology wasn't smart enough to switch itself off entirely and that there would be a fire risk so he's plugged it in to a timer that comes on for 12 hours every week during the day (so that his neighbours can see the garage in flames I guess). I think the timer is a bad idea as the C-Tek is self regulating but it made him happier.
    Try Batteries Direct - there's only $3 difference between the 5 & the 3.8
    400 Bad Request
    Jul 2010
    bracken ridge qld
    thanks for the replies. sounds like the way to go.batteries direct in sydney unfortunately.i know they will post but trying to save a bit. looking for something in brissy if possible. one question, does anyone know if my car would have an AGM or just the normal type lead/acid type?
    thanks again for the help.
    cheers
    warrick
    2011 3CC 3.6 V6. 19X8 CADWELL RIMS, K & N FILTER, EXHAUST TIPS,DBA SLOTTED FRONT DISCS,ATE CERAMIC FRONT PADS.
    Mindarie, Perth (WA)
    I get all my autoelectrical stuff from these guys: https://www.autoelec.com.au/contact.asp?_pic=0
    Service is awesome, pricing is even better and they offer an excellent warranty (which I am yet to use )
    https://www.autoelec.com.au/ssl/public_autoelec/store_v3/product_detail.asp?id=2097&cat=45
    Jul 2010
    bracken ridge qld
    hey guys
    does anyone know if the standard battery in the V6 3cc is AGM or plain lead/acid type? .
    cheers
    warrick
    Jul 2010
    bracken ridge qld
    this is what it looks like.i think normal lead acid. Varta 5ko 915 105 k.
    Charging Batteries in modern vehicles-varta-jpg
    Jul 2010
    bracken ridge qld
    no one knows the type of battery?
    warrick
    Have you checked with a Battery Retailer/Stockist?
    Jul 2010
    bracken ridge qld
    to be honest when i went to battery world i wasnt thinking about charging it up so didnt ask that question hence why i asked it here. he was less then helpful so i just wanted to leave. i am pretty sure its not AGM cause it has one of those glass eye things that change colour to indicate condition,green etc,and i didnt think the AGM batteries had them.
    cheers
    warrick
    reviewing the VARTA website, I'd confidently declare that's not an AGM battery.
