Results 1 to 5 of 5
Thread: Changing ipod in to Aux in - RCD500
    Oct 2014
    Hi Guys,
    I have an odd one. On my recently acquired 07 Gti, I have what appears to be an RCD500 unit fitted, though the manual suggests it should be a 300, so I'm assuming a previous owner upgraded, or the manual is wrong.
    Anyway...
    It has the ipod cable fitted in the glovebox, but I don't use apple devices. I would like to instead have an Aux input (3.5mm) so that I could at least play from my android phone/tablet. Ideally I would like a usb input.
    Is it possible, and easy, to switch over from ipod input to Aux input? What cables/converters will I need?
    Is there a usb input available? I can't seem to find anything suitable in my searching.
    I'm currently looking at this as an option for the Aux in:
    http://www.ebay.com.au/itm/like/321080991502?hlpht=true&ops=true&viphx=1&_trkparms =clkid%3D1367411697363940134&_qi=RTM1763577
    Anyone who has done this before and can lend advice would be most appreciated. Thanks!
    Current - 2007 Golf GTI, DSG, RCD510, K&N Panel Filter, BSH PCV revamp, Bluefin Stage 1 tune, 18" Omanyt's with RE003s.
    Previous - 2003 Renault Clio Sport 172 - Flame Red. -Gone-
    brisbane
    Oct 2014
    Thanks. So this would work on my rcd500 too?
    Does this have the CD input needed though? It is already a 6 stack in the dash?
    Thanks!
    Oct 2014
    Bump. Has anyone actually changed an ipod to a usb plug on an RCD500? Or am I dreaming? Thanks!
    Oct 2014
    So I ended up buying one of these to try:
    Micro USB TO 30 PIN Iphone 4 4s Dock 3 5mm Audio Adapter Converter Charger Cable | eBay
    It sort of works - if I hook my wifes ipad into the connector on my RCD500 and switch to aux input, it recognises the device and will accept the input. However if I use my android pad (it's a nexus 7) with the adapter above, it will not recognise the input. But if I start with the ipad connected, then remove it and connect the nexus, it remains connected (for a while at least).
    Anyone know how to get it to recognize my nexus every time I plug it in?
    Also - there is no power coming over the ipod plug from the HU (to either ipad or nexus). Is this a fault, or normal?
    Thanks!
