Results 1 to 8 of 8
Thread: CD stuck in Satnav/Audio system in Mk6
    Oct 2013
    Buderim Qld
    Hi All, I have a cd stuck in the SatNav/ Audio system in our Mk 6. Screen is displaying message saying "Error" CD.
    Kind regards
    Woodgrub
    Mar 2013
    Brisbane QLD
    try disconnecting the battery for 5 mins and back on...if doesnt work...remove the unit and move it around a little while pressing eject. if that fails then you can sometimes open up the unit and with a little playing around get the cd out....more likely a doggy cd then a head unit issue
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Oct 2013
    Buderim Qld
    Thanks very much. I will try your suggestions tomorrow.
    Mindarie, Perth (WA)
    try pressing "<" + ">" and "i" (button next to the eject button).
    Should reset the unit and most likely eject the disc when it restarts.
    Oct 2013
    Buderim Qld
    Hi Thanks for your help. I have tried the above suggestions but cd won't eject. Could you please advise me how to remove the unit as suggested.
    Regards
    Woodgrub
    Mar 2013
    Brisbane QLD
    in Mk6 just lever off the surround of the radio and there are 4 torq screws holding in the radio....thats it
    Oct 2013
    Buderim Qld
    Thanks for your help. Removed radio and tipped upside down whilst shaking, cd eventually ejected. CD has scratches on it where they weren't before so seems like something out of place in player. Thanks again.
    Woodgrub
    Pacific Paradise QLD
    Keep shaking, sounds like something else is in there as nothing in a CD drive that should scratch a CD as it is all above it till it gets right in and then drops down on the centre driving spindle.
