Results 1 to 7 of 7
Thread: Caravelle 2013 Replacing RCD215 with RNS510
    Mar 2012
    Emerald, QLD
    So, I have just installed my RNS510 in my 2013 Caravelle. It was an easy swap, but I am having some troubles figuring out the coding. The radio works fine, the SD card and HDD are fine. My vehicle had bluetooth, but it isn't recognising it now. The Navigation isn't working at all, but I am waiting on my map DVD to arrive, so not too worried yet. I haven't got the steering wheel controls to work properly yet either. I tried loading the firmware via CD (version 528x, or whatever the link was...) but it failed 3 times with different CD's. I am going to try a DVD later on. My current software version is 0972, should I just leave this? Hardware version H60. where should I be starting with this? I am a beginner with VCDS, but happy to learn, so if you can let me know where I need to look, that would be great!
    Below are the scan results after the install:
    Thursday,19,October,2017,17:57:31:18063
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
    Data version: 20170721 DS276.2
    Ross-Tech: Home
    Chassis Type: 6N0
    Scan: 01 02 03 04 08 09 10 15 17 19 25 37 4B 56 69 77 0B
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Cannot be reached 1100
    4B-Multifunc. Module -- Status: Cannot be reached 1100
    56-Radio -- Status: Malfunction 0010
    69-Trailer -- Status: OK 0000
    77-Telephone -- Status: Malfunction 0010
    Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 7H0 937 087
    Component: GW-K-CAN TP20 H32 0407
    Revision: BO032001
    Coding: 842300
    Shop #: WSC 02756 790 12345
    VCID: 70BAD8219AA77B77ABA-8024
    3 Faults Found:
    01300 - Control Module for Navigation with CD-Rom (J401)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 105
    Time Indication: 0
    00463 - Control Module for Digital Sound Package (J525)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 105
    Time Indication: 0
    03590 - Control Module for Multifunction Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 106
    Time Indication: 0
    Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
    Part No SW: 3C8 035 685 HW: 3C8 035 685
    Component: RNS-MID H60 0976
    Revision: B001001 Serial number: VWZ6Z7M9087040
    Coding: 00010440020000A30014
    Shop #: WSC 00040 040 00001
    VCID: 698CB545B97D8ABFEC4-803C
    5 Faults Found:
    00873 - Bass Speaker Rear Right (R17)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 145
    Mileage: 125104 km
    Time Indication: 0
    00872 - Bass Speaker Rear Left (R15)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 145
    Mileage: 125104 km
    Time Indication: 0
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 32
    Reset counter: 106
    Mileage: 125104 km
    Time Indication: 0
    00869 - Line Output; Rear Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 16
    Reset counter: 106
    Mileage: 125104 km
    Time Indication: 0
    00860 - Line-Output; Rear Left
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 16
    Reset counter: 106
    Mileage: 125104 km
    Time Indication: 0
    Address 4B: Multifunc. Module
    Cannot be reached
    Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
    5 Faults Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 145
    Mileage: 125104 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 7
    Reset counter: 145
    Mileage: 125104 km
    Time Indication: 0
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 32
    Reset counter: 106
    Mileage: 125104 km
    Time Indication: 0
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 16
    Reset counter: 106
    Mileage: 125104 km
    Time Indication: 0
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 16
    Reset counter: 106
    Mileage: 125104 km
    Time Indication: 0
    Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
    Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
    Component: TELEFON H15 3200
    Revision: 1B001001 Serial number: 00007664101250
    Coding: 0A01020000010101
    Shop #: WSC 02756 790 50316
    ASAM Dataset: EV_UHVNA 002720
    ROD: EV_UHVNA_002.rod
    VCID: 392C250589DDFA3F5C4-806C
    2 Faults Found:
    9457171 - Right audio channel for speech/telephone
    B104E 13 [008] - Short to GND
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 145
    Mileage: 125110 km
    Date: 2053.14.27
    Time: 10:48:25
    9458195 - Control Module for Cellular Telephone
    B1052 13 [008] - Open Circuit
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 242
    Reset counter: 146
    Mileage: 123443 km
    Date: 2053.14.00
    Time: 17:25:36
    Current Ride : 2013 Caravelle
    Previous Ride : 2001 Caravelle
    Looks like a North America unit.
    No use in Australia
    Mar 2012
    Emerald, QLD
    No use in Australia
    It is South Korean. The radio works fine, so no need to change the tuner card.
    I just need to figure out the programming for the navigation and bluetooth.
    Quote Originally Posted by Retch View Post
    Ah another one...
    Will need to be modified with low level tools before it MIGHT be possible to load EU firmware.
    Mar 2012
    Emerald, QLD
    Kamold, what are the modifications it needs?
    It may need a new tuner board, but this might be able to be modified.
    Then some low level settings would need to be changed (you would need setconfig or rnsmanager for this not possible with vcds or obd11 etc)
    Then load 5238 firmware.
    Then it may work.
    Then it may work.
    So I have just converted a Chinese RNS mainboard to EU.
    The tuner board was already an EU tuner so can't comment on the compatibility of the Korean tuner board.
    Using setconfig I changed the model Id and product ID, region etc.
    Then loaded a 4120 factory firmware image (modified images don't erase enough data and you end up with the unit stuck in German language only)
    Lastly loaded 5238 and latest maps.
