Originally Posted by
Entropy
Thanks for the replies guys, I tried the method mentioned above by Hillbilly:
However this didn't seem to work either
I think my next step will be to remove the entire centre console, the glovebox and panels under the steering wheel so I can have a better go at removing the cage as a whole.
I was reluctant to try this:
Are you sure this would work? How do you get the necessary purchase on the head unit to "yank" it out? I've tried pushing removal tool all the way in and applying some pressure while pulling the head unit out from behind (after removing the climatronic unit) and that didn't seem to work.
It's a bit disappointing, I was really looking forward to getting my nice new head unit in...
Has anyone got any pictures of what the stock head unit looks like when it's out? More specifically what the clips look like when they're out? The only pics I can seem to find online are of the "monsoon" head unit and not the one that came in Aussie Golfs.
Most clips you have to slide the pins into them and lever them away from the side of the unit as they normally drop into a slot in the unit.
Sometimes it helps if you push the unit in to take the pressure off the front edge of the clip If you pull it you will tighten their grip
