Results 1 to 10 of 10
Thread: Cannot delete navigation memory
    Jan 2013
    Can anybody tell me how to reformat the HDD?
    After few firmware upgrades I noticed that some destinations in the navigation memory cannot be deleted. Seems some part of the memory became corrupt.
    I tried to reset it, no success.
    MY18 VW Tiguan Comfortline
    Adelaide hills, SA
    Kamold should be able to help you. Or any member (sponsor) with setcofig for RNS510 units.
    Also look here RNS510 upgrades, repairs incl. coding. Who can help.
    From memory (i'll have to check) previous destinations are not stored on the HDD. So firmware upgrade will not remove them, same way radio presets are not removed. They are stored in seperate NVRAM.
    Unless the NVRAM is actually faulty, should be able to delete it with setconfig (a low level tool and software to access the RNS in debug mode).
    Jan 2013
    Hi kamold, thanks for the quick reply.
    This is not about previous destinations, this is about saved destinations so its the NVRAM probably as you mentioned.
    So should I bring it to the VW service and ask them to access it with setconfig?
    Or should I try to reset the whole unit, maybe that will clear the NVRAM?
    Vw do not have setconfig, it is an aftermarket tool.
    I will send you a pm see if I can assist.
    Jan 2012
    Epping, NSW
    I assume the factory settings option doesn't help?
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
    Jan 2013
    Quote Originally Posted by tonymy01 View Post
    It didn't help. Just downgraded the fw to 3810 now and tried again, but couldn't delete them. Bugger.
    Jan 2013
    Eureka! I managed to delete the entries!
    All of them had voice tag associated with it and I had to delete those voice tags first, then I was able to completely delete the entries.
    Thanks kamold for your kind offer, it seems I don't need to visit you after all.
    Good find. Hopefully will save someone else some frustration if they face the same issue.
    Mar 2019
    Victoria Point Qld
    Hi can you PLEASE let me know how to Delete voice tags.
    I have a second hand RNS510 and cannot get rid of all the old locations as they have voice tags on them
    Regards Adrian Brisbane Australia.
