Originally Posted by
AdamD
I believe that if it's done correctly (physical installation plus the coding with VAG-COM), then it's possible to get full functionality as per the factory, with the single exception of the antenna. When it's factory fitted you get the fin on the roof; when you don't spec sat-nav, you need to install a flat antenna (either inside but near the top of the dash, or else on top of the dash near the base of the windscreen I believe). I can't comment on the difference in signal strength/quality personally.
Mine still hasn't been sorted but I believe the dealer is working on it. I'm still missing voice activation and there are some saying it isn't possible but Maverick said it can so it must be so! Time will tell.
tornado red GTI MkVI, 5dr, DSG, Sat Nav, RVC, MDI.
Red Honda Fireblade Red Cooper S (SOLD)
